Bronco II Ford Bronco II
85 Bronco II starter/flywheel problem
Old Aug 23, 2005 | 04:13 PM
t-nip's Avatar
t-nip
Problem: 1985 Bronco II 4x4 2.8L 5 spd starter will not engage the flywheel. The starter checks out ok but it bendix spins when the starter is engaged. Any suggestions. I was told that possibly the flywheel ban needs replacing.
Old Aug 25, 2005 | 12:51 PM
tchile's Avatar
tchile
could very well be the starter solinoid/bendix. to check if it is the flywheel ring put it in gear and give the truck a nudge to move the fly to another spot and then try it. if it is the fly it should catch somewhere, if it is the starter the results will be the same as you are experiencing now.
Old Aug 25, 2005 | 07:11 PM
87ford4x4inline6's Avatar
87ford4x4inline6
Had a problem like that on my 84 ranger, after replacign 2 starters and the ring gear I found out that the starter was not shimmed correctly. I added a thin washer on one side and 2 on the other I have not had a problem in 2 years now.
Old Sep 15, 2005 | 05:48 PM
t-nip's Avatar
t-nip
I found the problem. The previous owner stripped the threads on the top bolt on the starter. I drilled and tapped the hole to a size larger and put in a the size bolt. Problem solved.
Old Sep 16, 2005 | 07:33 PM
Ken00's Avatar
Ken00
Glad to hear you got it fixed!!
Old Sep 21, 2005 | 05:09 PM
t-nip's Avatar
t-nip
still have problem
I spoke too soon. It started grinding and spinning after I started it about 6 times. Guess I will have to pull the trans and have the flywheel ban replaced. Any advice would be appreciated.
thanks
t-nip
Old Sep 22, 2005 | 03:00 PM
trinogt's Avatar
trinogt
Were there different flywheels through the years? say, early B2 to later B2? Someone actually told me that today on the phone!
Mark
Old Sep 22, 2005 | 05:11 PM
87ford4x4inline6
I am not for sure if there was actual different ones. I do know that a 86s will work on a 89 flywheel both auto and manual. I have swapped them with no problem.
NP435Bronco
15
Dec 1, 2025 09:45 AM
88F700
Large Truck
May 11, 2015 03:48 PM
Aviator2011
Bronco II
May 30, 2012 11:34 PM
dkkids5
1978 - 1996 Big Bronco
Sep 30, 2010 11:41 PM
rmckenna
Sep 14, 2006 04:30 PM
