Ok. Went out and Plugged the sensor back in and cleared the code. Appears to be working again! WTF???
Got it warmed up - This is the stock tune on my DP Tuner.
I did a couple WOT for as long as I could hold it (am in a city)
Yep... textbook stock. We really need to catch this in the act. I noticed you have that version of AE with the wonky FIPW reading. It can easily be corrected, though: Open up your settings for FIPW, change the Scale Value to 10, then close it. Open it again and reset the max to 5. For some strange reason, if you do both at the same time, AE sometimes won't keep the max you set.
Yeah. I actually just talked to Bill and he sent me the upgrade from 13.0.0 to 13.0.1
So everything else looks pretty good? Even the drive home went fine and I switched to one of my tunes. No issues. I have noticed that the idle appears to be fighting to stay smooth. Like a vacuum leak in a gasser. Any thoughts on what to check there?
Idle is a beast with HEUI injectors - it's like the moon and planets need to line up to get a smooth idle at all times. There are levels of a rough idle, and that's something that can't be conveyed on the forum - except by PERDELs, if you know what to look for and what to look out for.
