Offroad & 4x4
dana 44
Old Sep 2, 2007 | 07:39 AM
bigbubba87's Avatar
bigbubba87
dana 44
i have a 73 f250 highboy it has a dana 44 front end how do i tell if it is the origonal highboy front end? and also what is the difference between the highboy dana 44 and the regular dana 44 thx justin
Old Sep 2, 2007 | 07:45 AM
teds74ford's Avatar
teds74ford
They are closed knuckle (I think), low pinion, and drum brake. There is no appreciable difference in dana 44s. Just the mounts. Some had thicker tubes. Some had open knuckles. Some had discs.
Old Sep 2, 2007 | 08:02 AM
bigbubba87's Avatar
bigbubba87
this one is a d6ta-aae it has disk brakes to
Old Sep 2, 2007 | 01:24 PM
teds74ford's Avatar
teds74ford
Doesn't sound stock. Is it open knuckle too?
Old Sep 2, 2007 | 11:26 PM
bigbubba87's Avatar
bigbubba87
whats is closed and open knuckle i havent ever paid much attention
Old Sep 3, 2007 | 08:15 AM
teds74ford's Avatar
teds74ford
At the "C" where the u-joint is, a closed knuckle looks like a ball. Here's a picture of what open looks like.
You can see the u-joints at the ends
Old Sep 4, 2007 | 03:50 PM
bigbubba87's Avatar
bigbubba87
mine is just like that i havent had no luck finding and axle
Old Sep 4, 2007 | 06:22 PM
teds74ford's Avatar
teds74ford
Sooo....what are you trying to do? Do you need a replacement axle? Others will bolt in.
Old Sep 4, 2007 | 08:24 PM
bigbubba87's Avatar
bigbubba87
what other axles will work? i just want to find a replacement axle
Old Sep 5, 2007 | 08:18 AM
teds74ford's Avatar
teds74ford
I am not the leaf spring guru, but up through 77.5 they made the highboy. 76-77.5 were open knuckle disc brake. What is wrong with the axle that's in it?
Old Sep 5, 2007 | 03:45 PM
bigbubba87's Avatar
bigbubba87
i guess the U joint went out and it broke the deals off that hold the u joint in place
Old Sep 5, 2007 | 07:36 PM
teds74ford's Avatar
teds74ford
You don't need a whole new axle, just a shaft.
Old Sep 5, 2007 | 07:59 PM
79superduty's Avatar
79superduty
high pinion or low?
Old Sep 6, 2007 | 06:33 AM
bigbubba87's Avatar
bigbubba87
i just need the passenger side shaft i think its low pinion but im not sure i lost all the records on this truck it has had a different front end put in it i know that but i dont know which one i have it tore apart in my shed now so what would tell me if its high or low pinion?
Old Sep 6, 2007 | 06:36 AM
bigbubba87's Avatar
bigbubba87
where do i measure to see what axle i would need
