A/C PROBLEM
Old Jan 21, 2015 | 12:44 PM
MarauderV8's Avatar
MarauderV8
A/C PROBLEM
The VCM with IDS list me the trouble code B2477, DATC isn´t configured. If i try to config it with IDS, i have to insert a code and the note, that i can get it on a dealer webside, but i don´t have access here from Germany. How can i find out the right code?
I have to configure it, because in the morning, the system blow only cld air, till i select every switch one by one, than i get warm air.
Thank you so much for help
Old Jan 21, 2015 | 02:07 PM
alloro's Avatar
alloro
I believe the B2477 code indicates a problem with the ABS brake module and has nothing to do with the climate control.
For the cold air only problem, you could have the infamous broken blend door issue.
Old Jan 21, 2015 | 02:39 PM
MarauderV8's Avatar
MarauderV8
No, is for the DATC:
B2477-60- EATC module config failure
ArmamentDawg
1983 - 2012 Ranger & B-Series
15
Dec 20, 2017 07:00 PM
Dragon600
2004 - 2008 F150
Jan 5, 2013 10:34 AM
fixnair
Electrical Systems/Wiring
Aug 11, 2010 11:45 PM
chefbill
Mar 19, 2002 09:28 AM
