Airbag light flashes the 52 25 code
Old Jul 21, 2003 | 04:18 PM
jwitter's Avatar
jwitter
Question Airbag light flashes the 52 25 code
I just replaced the battery on my '98 Expedition and now the airbag light flashes 5 series of 52 and/or 25. Can anyone tell me what this code stands for? Thanks, JWitter
1998 Expedition EB 4*4
52XXX miles
Old Jul 25, 2003 | 12:22 PM
steve83's Avatar
steve83
This is the airbag code list for a 96 Explorer:
AIR BAG DIAGNOSTIC MONITOR DIAGNOSTIC TROUBLE CODE (DTC) PRIORITY TABLE
DTC...........LFC..........Description............ .....................................Action To Take
B1342.........24............Internal microprocessor fault..........................GO to Pinpoint Test A.
...................................(retrieved only during on-demand self test)
B1867......12/52.........Lost battery feed or low battery...................GO to Pinpoint Test B1867.
...................................feed voltage
B1869..........- .............No air bag indicator - Inoperative............GO to Pinpoint Test C.
...................................indicator circuit
B1913......13/53.........Air bag driver/passenger circuit...................GO to Pinpoint Test B1913.
...................................short to ground
B1914......14/54.........Primary crash sensor circuit shorted...................GO to Pinpoint Test B1914.
...................................to ground
B1921.........21...........Air bag diagnostic monitor ground...................GO to Pinpoint Test B1921.
...................................circuit open or not mounted to vehicle properly
B1922.........22...........Safing sensor output circuit shorted...................GO to Pinpoint Test B1922.
...................................to battery voltage
B1923.........23...........Memory clear circuit improperly...................GO to Pinpoint Test B1923.
...................................grounded
B1924.........24...........System disarm failure or internal...................GO to Pinpoint Test A.
...................................diagnostic monitor fault
B1932.........32...........Driver side air bag high resistance...................GO to Pinpoint Test B1932.
...................................or open
B1933.........33...........Passenger side air bag circuit high...................GO to Pinpoint Test B1933.
...................................resistance or open
B1934.........34...........Driver side air bag circuit low...................GO to Pinpoint Test B1934.
...................................resistance or shorted
B1935.........35...........Passenger side air bag circuit low...................GO to Pinpoint Test B1935.
B1941.........41...........RH primary crash sensor feed/return...................GO to Pinpoint Test B1941.
B1942.........42...........LH primary crash sensor feed/return...................GO to Pinpoint Test B1942.
B1944.........44...........RH primary crash sensor not mounted...................GO to Pinpoint Test B1944.
...................................to vehicle properly or ground circuit open
B1945.........45...........LH primary crash sensor not mounted...................GO to Pinpoint Test B1945.
DTC - Diagnostic trouble code, retrieved using New Generation Star (NGS) Tester 007-00500 or equivalent.
LFC - Lamp fault code, flashed on air bag indicator.
{Searchable: 1996 '96 Ex airbag}
Old Jul 25, 2003 | 02:21 PM
jwitter's Avatar
jwitter
Exclamation Airbag light flashes the 52 25 code
I figured out the code finally on the internet. I had a oil change scheduled at my Ford dealer anyway so I asked them to reset the light without running any tests because I knew what the code was for. When I received my bill I saw the $6 for the oil and filter change and $35 for resetting the light. I was amazed!. I kindly asked my salesperson about it and he said that was normal. He said they charge everyone the $35 fee along with the cost of the battery when they replace one as well. I didn't say much but I would have been much better off going to autozone (free) or putting the money towards a superchips computer. Anyway, thanks to those who replied.
esten07
2004 - 2008 F150
Dec 12, 2015 07:42 AM
gtmustang00
Jan 18, 2014 10:07 AM
mbowker64
1997 - 2003 F150
Jul 26, 2010 11:24 PM
whruppe
Aerostar
Jan 16, 2008 09:05 PM
chaser1602
1997 - 2003 F150
Aug 31, 2005 12:37 PM
