Offroad & 4x4
How do I correct this coil spring bow?
Old Feb 11, 2015 | 07:19 PM
2x4 to 4x4's Avatar
2x4 to 4x4
Old Feb 11, 2015 | 07:20 PM
2x4 to 4x4's Avatar
2x4 to 4x4
Sorry for the bad pic, but the wedge is under the lower bucket
Old Feb 12, 2015 | 05:05 AM
tjc transport's Avatar
tjc transport
i ain't rite
what did you do with ball joint angle?
with the axle being tilted like that, the steering geometry will be all screwed up giving you a caster and camber that will never be rite.
the proper way to do it is to have the ball joint angle 90 degrees to the road, then put the spring perches on the axle. then you also have pinion angle, you want no more than around 30 degrees or you will constantly eat universals.
so when doing a large life you need to first figure out and set your pinion angle, then cut off the axle tube ends so you can properly clock the balljoints, and then finally mount the lower spring perches. then drop the radius arm brackets, and make a set of radius arms to lock it all in place. once that is all done, you can mount it in the truck and you will not have to worry about it.
Old Feb 12, 2015 | 06:51 PM
2x4 to 4x4's Avatar
2x4 to 4x4
I have not done anything with the ball joints. this axle came off a 87 Bronco ll that used these same coils. The ball joints look to be straight up and down and at 90 degrees with the tierods.
Old Feb 12, 2015 | 09:08 PM
bigdan1979f-250's Avatar
bigdan1979f-250
You say you are putting in a Dana44 front axle. Is it a Twin Traction Beam axle? Because if you got it off an 87 Bronco 2 it is. I am not aware of any that came with a solid axle. If using TTB axle I think you have your work cut out for you as they are a different animal from what I have seen. Especially when converting from 2wd to 4wd.
Old Feb 12, 2015 | 09:15 PM
2x4 to 4x4's Avatar
2x4 to 4x4
I should have clarified a bit more... Sorry.... Originally this came out of an older f150 i believe 79 maybe. A friend put it in the bronco ll i got that and cut it up for scrap, but kept the axles.
Old Feb 12, 2015 | 09:22 PM
bigdan1979f-250
Ok that makes sense. My recommendation would be either drop brackets or longer radius arms then. How much lift does this setup have?
Old Feb 12, 2015 | 09:27 PM
2x4 to 4x4's Avatar
2x4 to 4x4
Old Feb 12, 2015 | 09:29 PM
2x4 to 4x4's Avatar
2x4 to 4x4
Old Feb 12, 2015 | 09:33 PM
2x4 to 4x4's Avatar
2x4 to 4x4
The first pic is the day I got it, the second is right after I got the front axle in. It looks good in the pic but none of the steering is hooked up and the radius arms are clamped to the frame. The drag link was also coming off the front of the gear box so when I turned left the tires turned right.
Old Feb 14, 2015 | 07:52 PM
bigdan1979f-250
Should have left the steering the way it was originally. Great anti theft feature and would really make your brain work overtime when driving.
Old Feb 14, 2015 | 07:54 PM
2x4 to 4x4's Avatar
2x4 to 4x4
Yea but it would make for some odd wheeling. I thought about it for on road. Some of the looks I'd get turning the wheel left and going right.
Old Feb 15, 2015 | 05:09 AM
  #28
gatorfor88's Avatar
gatorfor88
Would keep you from driving impaired too.
460 FORD MAN
Sep 11, 2012 11:30 PM
American Thunder
Oct 6, 2010 05:08 PM
4tl8ford
May 25, 2010 07:11 PM
abelmoreno
Dec 15, 2005 12:21 PM
tomoad
Feb 5, 2005 05:10 PM
