Polyurethane coil spacers
Old Dec 8, 2005 | 11:15 PM
abelmoreno's Avatar
abelmoreno
Hello everyone,
I'm thinking on getting a pair of these Daystar polyurethane lifts with the lug extensions. I already have a 6 inches skyjacker lift undert my truck. My real question is: Will this set of 2 coil spacers only lift the front end of my truck? It might sound stupid but I think I read that somewhere. Please let me know.
Thanks
Old Dec 9, 2005 | 12:29 AM
ws595's Avatar
ws595
Yes, coil spacers will only raise the front of the truck.
-R.
Old Dec 10, 2005 | 10:26 AM
abelmoreno's Avatar
abelmoreno
makes sense... To raise the back in order to level the truck... after the coil spacers installation... an extra spring leave on the back would be enough? Which one? How do I calculate final height before installation?
Old Dec 10, 2005 | 11:17 PM
mdjohnson's Avatar
mdjohnson
I bought some coil spring spacers for my 94 from Advanced Auto Parts for like $7.74 a piece, the body is almost perfectly level.
Old Dec 11, 2005 | 10:59 AM
omni's Avatar
omni
how did you get thoses so cheap, I thought they were like 100.00 +tax for a pair
Old Dec 11, 2005 | 11:47 AM
mdjohnson's Avatar
mdjohnson
Thats how much they were was $7.74 a piece, they are a polyurathane coil spacer you just push in.
Old Dec 11, 2005 | 12:11 PM
abelmoreno's Avatar
abelmoreno
How many inches were those spacers? Did you purchase them online, where?
Old Dec 11, 2005 | 04:01 PM
wrenchturner's Avatar
wrenchturner
the parts he is talking about are some rubber blocks or the twist in kind. either one i would NOT put in a front suspension. The spacers that you are talking about a cool and i'm looking at them also. your shocks will be fine and you'll retain a factory ride quality.
Old Dec 12, 2005 | 03:47 PM
raysvan's Avatar
raysvan
I have seen coil spring boosters at AutoZone that go under the coil spring, gives it about 2 inches of lift. They claim not to change ride quality either. I bought my truck with the rear beefed up for hauling a horse trailer and the rear springs are really firm and has the truck up probally 5 inches higher than the front, to me that is to much. Has anyone used the type of coil shim I speak of?
Old Dec 13, 2005 | 02:03 PM
mdjohnson's Avatar
mdjohnson
It raised my front end about 1" to 1.5" they are a full coil rubber spacer. In the package they look like a black circle that is split.
Old Dec 14, 2005 | 11:19 PM
abelmoreno's Avatar
abelmoreno
I know now which ones youre talking about. Did these come to you with the extension bolt? Any problems there?
Old Dec 14, 2005 | 11:32 PM
Fully_Loaded's Avatar
Fully_Loaded
These spacers will change the geometry of youe camber adjustment. You will need radius drop brackets for anything over about an inch or you will go through tires like no tomorrow. I am going through this now. I have adjustable camber bushings and they are maxed out and still not right.
Old Dec 15, 2005 | 12:21 PM
mdjohnson's Avatar
mdjohnson
I put new ball joints in my truck and when I was done I have a lot of negative camber. I put the spacers in and I'm now back to a factory alignment.
Skyjacker sell aftermarket camber adjusters that rotate a full 360º to get a proper alignment.
The spacers I got didn't come with an extension bolt.
tabascom16
Mar 2, 2015 07:01 AM
W1d0wmak3r
Jun 12, 2014 02:06 PM
'78f350
Apr 17, 2014 06:28 PM
TheKirbyMan
Feb 5, 2010 06:28 AM
93BigBlackBronco
1978 - 1996 Big Bronco
Apr 8, 2005 09:27 PM
