Coil spring not seating
Old Sep 11, 2012 | 09:29 PM
460 FORD MAN's Avatar
460 FORD MAN
I installed the 2" lift coil springs and the driver side went on with out a hitch.
But the passengers side isn't seating correctly. Anybody had this happen? I had to disconnect the trac bar to lower the axle enough of get the coil in. So do I need to get a lower drop down mount or longer trac bar?
Here's the coil with weight on it. You can see what I mean, I can stick my finger under the coil spring.
Thanks guys
Old Sep 11, 2012 | 10:02 PM
robs_seven's Avatar
robs_seven
I put a new coils on mine, 2" leveling kit. My driver side was no problem. Then the passenger was a pain. The coil seat was off and didn't want to mount in. The shock and coil were both leaning inward. Plus the entire axle was off center. For 2" from what I'm told doesn't need anything extra but I made a drop track bar bracket. It moved things back inline. It's still not 100% perfect but the coil seated and now they don't lean in.
Just telling you what I encountered. I'm still new to these trucks so others will give you more info for sure
Old Sep 11, 2012 | 10:09 PM
460 FORD MAN
Thanks man, any info is much appreciated!
Old Sep 11, 2012 | 10:59 PM
robs_seven's Avatar
robs_seven
I had a thread about my issue and a picture of the bracket I made. May or may not help.
Old Sep 11, 2012 | 11:20 PM
460 FORD MAN
Do you remember what it was titled?
Old Sep 11, 2012 | 11:30 PM
robs_seven's Avatar
robs_seven
"76 F100 Suspension Question"
302flareside1992
Offroad & 4x4
27
Feb 15, 2015 05:09 AM
mikerans
May 20, 2012 01:50 PM
4tl8ford
May 25, 2010 07:11 PM
79Ford4x4
Offroad & 4x4
Jan 19, 2010 12:05 AM
Destroyer
1978 - 1996 Big Bronco
Apr 2, 2004 10:24 PM
