Sponsored by: Real Truck
Need help in nj
Old Jan 18, 2015 | 08:48 PM
slimed8's Avatar
slimed8
Need help in nj
Is there anybody that knows how to work on 7.3psd's that lives in burlington nj or close by?
Old Jan 18, 2015 | 08:59 PM
05F250DSL's Avatar
05F250DSL
I'm not anywhere near but maybe post your issue and we can walk you thru it. We have some very knowledgeable members here.
Old Jan 19, 2015 | 08:44 AM
slimed8's Avatar
slimed8
Okay do the best I can. I have a 02 f350 with 7.3 all stock. Have a superchips tuner. Have the mileage settings programmed. Driving home got on it a little bit heard a pop then has no power, when you try to accelerate blows out black smoke. Also has bad fuel consumption. Hooked up programmer came up with p1249, p0231, P0603
Old Jan 19, 2015 | 08:55 AM
02TB250's Avatar
02TB250
Based on a quick google search it looks like you have a wastegate issue, a fuel pump issue and a pcm issue. Tuner might have damaged the truck. I would post over in the diesel forum they may be of a little better assistance.
Old Jan 19, 2015 | 09:07 AM
Poncho450's Avatar
Poncho450
Also - try http://www.thedieselstop.com/forums/
Got a lot of great information there when I owned a 7.3
Old Jan 19, 2015 | 09:32 AM
05F250DSL's Avatar
05F250DSL
Pop and no power + smoke i would first check all your boots. They connect your turbo to the intercooler and intercooler to intake. Sounds like you may have popped one. Usually it's the hot side that goes first (from the turbo to intercooler) give them a good look over.
Old Jan 19, 2015 | 11:30 AM
slimed8's Avatar
slimed8
ok thanks guys.hopefully it's the boot I just had that passenger side boot off to do glow plugs.I will try that other site and the diesel forums thanks again
kbarbee95
22
Jan 31, 2015 10:37 AM
cg21
23
Sep 20, 2013 03:10 PM
slim613
23
May 31, 2011 08:08 PM
kent's f-350
Sep 19, 2008 01:26 AM
santacruzf250
Nov 6, 2007 11:06 AM
