THROTTLE LINKAGE:
Old Jan 18, 2015 | 01:23 PM
leonharu's Avatar
leonharu
THROTTLE LINKAGE:
Does anyone have a diagram on the throttle linkage on a 1966 F-100 with 352 engine with manual transmission?
Old Jan 19, 2015 | 01:29 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C5TZ-9A758-AH .. Accelerator Cable-20" long / Reproduced
Applications: 1965/66 F100/250 352 2WD
Old Jan 19, 2015 | 05:26 AM
leonharu's Avatar
leonharu
Thanks ND.For some reason I have the bracket at the coil mount but no spring (9737) on diagram.There is a different spring at the rear down under the cable linkage???Is there a ford part number for this particular spring(9737)?For some reason the idle speed on my truck sometimes never dropped all the way down because throttle is not all the way closed.Hope this makes since?
Old Jan 19, 2015 | 05:41 AM
jowilker's Avatar
jowilker
Russ, Any ol spring will work till you find the right one for you. Toe under the pedal will work too although a little like a hemoriod.
John
Old Jan 19, 2015 | 05:46 AM
leonharu's Avatar
leonharu
Hello John,I guess I need to make a trip to Ace Hardware!!Dang,I have had the truck 14 years and just now realized something ain't right!
Old Jan 19, 2015 | 09:05 AM
NumberDummy
There are two springs. Coil spring that hooks to the coil bracket...then hooks to the carb linkage.
There's another spring that attaches to the suspended gas pedal (9C804 in pic). When it breaks, the gas pedal flops around.
C5TZ-9737-C .. Coil Spring / 5.51" long - 17 coils - .75" O.D. / Obsolete
Applications: 1965/66 F100/350 352 M/T / No Ford dealer or obsolete parts vendor has any.
C5AZ-9C804-B .. Accelerator Pedal Pivot Spring-Use with suspended pedal / Obsolete
1965 F100/250 2WD 240/300/352 from serial number 696,001 / 1966 F100/250 2WD 240/300/352 // 1965/68 Galaxie / 1966/73 Bronco / 1968/71 Thunderbird / 1971/72 Mustang/Cougar.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 13 = 800-476-9653.
GREEN SALES CO. in Cincinnati OH has 26 = 800-543-4959.
SatinBlack03
Modular V10 (6.8l)
Jun 4, 2016 12:50 PM
miihere24
26
May 26, 2013 08:25 PM
LARIAT 85
Jul 30, 2010 09:17 AM
cjben
May 2, 2005 11:30 PM
FirstF150
Feb 11, 2002 08:45 PM
