throttle return spring ideas needed
Old May 2, 2005 | 07:59 PM
cjben's Avatar
cjben
I just installed a edelbrock 1406 600 cfm on my 1978 f100 with a swapped in 86 351w HO. I am using a wieand stealth intake manifold. i need ideas for a throttle return spring. where can i mount one so i can have tension on the throttle linkage? I have no studs,or brackets anywhere on the engine I can attach one end of the spring to. just need some ideas what others have done. thanks,Ben
Old May 2, 2005 | 09:10 PM
rainbowATF's Avatar
rainbowATF
You can find a return spring mounting bracket in the performance section of Advance Auto or Autozone. Mr. Gasket is one supplier.
Old May 2, 2005 | 11:30 PM
LxMan1's Avatar
LxMan1
You should be able to use the throttle cable bracket that is bolted to the rear of the intake with a long enough spring and hook to the bottom of the carb linkage. That's what I did on my 63 F100 with a 351HO in it.
