2000 tranny replacement help
Old Jan 16, 2015 | 09:05 AM
henrymiller1's Avatar
henrymiller1
My automatic tranny is limping along.
My mechanic suggested getting one from junk yard.
$150 we find it and pull it. What tranny can i use?
2000 F250 7.3 with 250K miles.
VIN1FTNX21F3YEA15364
Thanks,
Old Jan 16, 2015 | 09:46 AM
Ford79's Avatar
Ford79
1999 to 2003 4R100 from a 7.3 truck in the same configuration as yours (2wd or 4x4)
Old Jan 16, 2015 | 10:58 AM
Kamstutz's Avatar
Kamstutz
If you plan on keeping your truck, I would have the original rebuilt. A yard one can go bad 6 months down the road. Even if you get a yard trans, I would still get a billet TC.
Old Jan 16, 2015 | 06:19 PM
snknby123's Avatar
snknby123
yeah, it's a gamble pulling one from the yard. You could get lucky and find a low mileage truck but even then it's still a gamble.
For $150 though, that's worth the core charge all day long. You can send it for rebuild while you limp the current one in your truck along while you wait.
Your inspection should include looking for leaks at the TC area etc. Inspection of fluid can also be a clue. Other than that roll the dice.. Good luck
Old Jan 20, 2015 | 10:46 AM
SDElwood's Avatar
SDElwood
Beer Fridge Finder
Maybe this will help....
2000 FORD F250 SUPER DUTY
VIN: 1FTNX21F3YEA15364
  • 4 Door Extended Cab Pickup
  • 7.3L V8 DIR
  • 4 wheel drive
This is an excerpt from the CARFAX Vehicle History Report.
<table id="serviceHistoryTable" class="table-block"><thead> <tr class="top-row"> <th scope="col" id="dateTitle">Date</th> <th scope="col" id="odomTitle">Mileage</th> <th scope="col" id="serviceTitle">Service Performed</th> </tr> </thead> <tbody> <tr class="recall"> <td class="iconified">
</td> <td class="miles">
</td> <td class="service"> Manufacturer Safety recall issued on 10/14/2009
Recall #09S09
SPEED CONTROL SYSTEM MODIFICATION
Locate an authorized Ford or Lincoln Mercury dealer or call 866-436-7332 to obtain more information about this recall
</td> </tr> <tr class="recall"> <td class="iconified">
</td> <td class="service"> Manufacturer Safety recall issued on 12/04/2007
Recall #07S57
CAMSHAFT POSITION (CMP) SENSOR INSPECTION
REPLACEMENT
</td> </tr> <tr class="odd"> <td class="date">07/25/2008</td> <td class="miles">108,530</td> <td class="service"> Fluids checked
</td> </tr> <tr class=""> <td class="date">10/08/2007</td> <td class="miles">93,210</td> <td class="service"> Transmission computer/module checked
</td> </tr> <tr class="odd"> <td class="date">12/11/2006</td> <td class="miles">
</td> <td class="service"> Pre-delivery inspection completed
Safety inspection completed
Drivability/performance checked
Exterior lights checked
</td> </tr> <tr class=""> <td class="date">12/23/2003</td> <td class="miles">61,979</td> <td class="service"> Maintenance inspection completed
Fuel filter replaced
Glow plug(s) replaced
Glow plug relay replaced
Engine checked
Battery/charging system checked
Glow plug system checked
Engine compression checked
Engine/powertrain computer/module checked </td></tr></tbody></table>
Old Jan 21, 2015 | 07:21 AM
henrymiller1
Thanks.
Thanks again,
Not sure what i'll do, but may grab one and have it rebuilt while i limp with this one. Good call snknby123.
I'll look into Billet TC.
msgtg
West Virginia Chapter
18
Jan 5, 2010 08:31 AM
HOOKY
Dec 13, 2007 07:43 PM
dyrtbyrd
15
Jul 3, 2007 01:12 PM
CruiserClass
May 6, 2007 09:51 PM
zanec209
Jul 11, 2004 10:15 PM
