Time delay relay
Old Jan 17, 2015 | 07:16 PM
jetdoc's Avatar
jetdoc
Time delay relay
Im looking for a automotive time delay relay for my stereo. I bought a Alpine double din head unit and it doesn't like "waiting to start". Any body have the same problem?
Old Jan 17, 2015 | 10:46 PM
whitetmw's Avatar
whitetmw
You might want to try a 12VDC Capacitor inline with the power wire. They'll last 30 - 45 seconds.
Old Jan 18, 2015 | 01:22 AM
montanasteve's Avatar
montanasteve
I dealt with Altronix products a bunch in my former career. I believe this one will do what you're looking for: Altronix Products: 6062 - Multi-function Timer 12/24VDC.. Probably in the $20-30 range.
Old Jan 18, 2015 | 06:13 AM
jetdoc's Avatar
jetdoc
That could be what I'm looking for. I've went through two head units so far. I'm beginning to think that interrupting the radios start cycle with the WTS of a diesel has led to their early demise.
Old Jan 18, 2015 | 06:17 AM
Tugly's Avatar
Tugly
Physical damage or firmware damage? Or... could it be like me: The other sets were the "bargains", so it was Quarter Caliber damage.
Old Jan 18, 2015 | 06:23 AM
jetdoc's Avatar
jetdoc
Firmware. Unfortunately it has to be sent back to Alpine every time.
Old Jan 18, 2015 | 06:52 AM
F350-6's Avatar
F350-6
Could you link to one from Radio Shack or somewhere? Sounds easy enough but there are lots of capacitors and I don't know enough about them to understand what I'm looking for. I'd love to have one for the air compressor on my wife's truck (more amps than the radio).
Old Jan 18, 2015 | 08:18 AM
jetdoc's Avatar
jetdoc
I don't need it to stay on longer just to delay the start of the unit. When I turn the key on for the glow plugs to radio starts to boot. When I start the engine the power is interrupted and that corrupts the head unit. I loose my fancy GPS and British sounding chick that calls me 'big daddy'.....I'm so lonely now.....
Old Jan 18, 2015 | 10:18 AM
Tugly's Avatar
Tugly
A thought... as silly as it may sound:
What if there was a relay coil on the GP side of the GP relay?
I'll explain it a little better: N/C contacts between the radio power to the radio. GP side of the GPR to one leg of the radio relay coil, the other leg to ground. The radio wouldn't see power until the key is on and the GPR is off.
One other thought - voltage-sensing relay: Anything less than 12 volts shuts off the power to the radio. Either plan would prevent sub-par voltage from reaching the apparently sensitive electronics.
Last thought: Low voltage isn't a highly-likely culprit - noisy voltage is. If you have damaged contacts on your GPR or starter relay, this could certainly cause issues on sensitive electronics.
Old Jan 18, 2015 | 10:34 AM
jetdoc's Avatar
jetdoc
I like that GPR idea......Trying to wrap my head around how to wire that up....
Old Jan 18, 2015 | 10:42 AM
Tugly's Avatar
Tugly
*EDIT* Single Pole Double Throw Relay - SPDT
Without a diagram:
Coil + to GPR on the GP side (big stud).
Coil - to ground.
That's to control the contacts.
Contact COM (Common) to the key power.
Contact NC (normally closed) to the radio power in.
That's it.
Key ON GP ON, no radio.
Key OFF, no radio.
Key ON, GP OFF, radio power.
Radio comes right on with a dead-cold truck, bad GP circuit.
Old Jan 18, 2015 | 11:30 AM
jetdoc's Avatar
jetdoc
Without a diagram:
Coil - to ground.
That's it.
Key OFF, no radio.
Gotcha! Thank you!
Old Jan 18, 2015 | 11:36 AM
Shovelheadrob's Avatar
Shovelheadrob
I posted this link Think Harder » How To Keep Your Radio On When You Start Your Car as a solution in another thread about the same problem, I need to find the time to make it work as I have a Pioneer double din unit that has just about booted up when the WTS lamp has gone out, then it's wait again once the key has been cycled, it hasn't caused any damage just a PITA!
Old Jan 18, 2015 | 05:57 PM
F350-6's Avatar
F350-6
The problem with using the GPR is that it comes on with the key and doesn't give you the delay. (That's where I've got the compressor for the wife's truck pulling the trigger from.)
Old Jan 18, 2015 | 10:35 PM
Tugly's Avatar
Tugly
Originally Posted by F350-6
The problem with using the GPR is that it comes on with the key and doesn't give you the delay....
The way the relay is configured, it operates in reverse of what you're saying there. The active GPR prevents the power from reaching the radio.
