brakes
Old Jan 16, 2015 | 07:26 PM
wilmw's Avatar
wilmw
brakes
What's the best way to convert a '67 f250 to front disc brakes?
Old Jan 16, 2015 | 07:48 PM
HIO Silver's Avatar
HIO Silver
Welcome to FTE...get a set of, IIRC, 72 and later brackets, rotors, etc.
These two threads should highlight all that is necessary:
Started the disc brake conversion - The FORDification.com Forums
#50: 1972 F250 8,100lb GVW Disc Brakes (Tons of Photos) - The FORDification.com Forums
Old Jan 16, 2015 | 08:08 PM
wilmw's Avatar
wilmw
What is IRC?? And will the rotors fit the drum spindle? Also will I need a different master cylinder?
Old Jan 16, 2015 | 08:10 PM
Tedster9's Avatar
Tedster9
IIRC, if I recall correctly
Yeah, a disc/drum setup uses a different master cylinder.
Old Jan 16, 2015 | 08:15 PM
HIO Silver's Avatar
HIO Silver
Your question will be answered by the threads I posted.
C'mon man, we'll provide you the information resources by those who have done it before... and done well I might add.
If ya get stuck, then we can chime in.
Old Jan 16, 2015 | 08:25 PM
wilmw's Avatar
wilmw
I asked what was an IRC sorry but replying IIRC still doesn't help me!! Not stuck.. just trying figure if I can do this without buying a $1000 kit.
Old Jan 16, 2015 | 08:28 PM
HIO Silver's Avatar
HIO Silver
I asked what was an IIRC sorry but replying IIRC still doesn't help me!! Not stuck.. just trying figure if I can do this without buying a $1000 kit.
Yes, yes you can. We believe in you.
Please read through those threads rather than us being redundant and repetitive.
Old Jan 17, 2015 | 03:44 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1968/72 F250 2WD's were available with optional dual piston caliper disc brakes.
Disc brakes became standard equipment on 1973 F250 2WD's, but there were two different types:
With single piston calipers or dual piston calipers...as it depended on what the GVWR (Gross Vehicle Weight Rating) was.
chucks65
Feb 6, 2018 01:01 PM
crazed87bronco
Sep 28, 2010 06:42 AM
SCBarger
Sep 13, 2010 08:39 AM
pockets
15
Feb 19, 2005 07:43 PM
inliner
May 2, 2003 09:49 AM
