upfitter switch utilization
Old Jan 14, 2015 | 08:07 PM
14SD4Jeffro's Avatar
14SD4Jeffro
Exclamation upfitter switch utilization
so, please, by all means, correct me if I'm wrong, but this is how I see it:
1) after mounting my lights (I HOPE they're females )
2) power wire from lights to pass through wire
3) opposite end of pass-through to wire for whichever particular switch I should choose to use
4) simple as that...no <additional> relays needed & simply be mindful of amp rating of accessories
can it really be this simple
Old Jan 15, 2015 | 02:54 PM
Franklin2's Avatar
Franklin2
That's why they put them there, to make it easier. I can't remember if the upfitters already have fuses installed or not.
Old Jan 16, 2015 | 08:24 PM
Cafeguzzi's Avatar
Cafeguzzi
Chose wisely
i believe switch 1 and 2 are 25-30 amp swithces. 3 and 4 are 5-10 amp. So if your lights are high draw use the heavier switchers. Be sure to use the inline fuse feeding the lights.
Old Jan 17, 2015 | 07:09 AM
Franklin2's Avatar
Franklin2
Each upfitter already has a spot in the fuse box for a fuse, I just can't remember if they installed them or not. They should be good enough to protect the circuit.
maineguy53
All Things Towing
Jan 24, 2018 06:11 AM
rews2
Aug 4, 2014 12:43 PM
spongecop
Nov 5, 2012 02:15 PM
Byram
Electrical Systems/Wiring
Oct 6, 2010 09:10 PM
88grandmarquis
Sep 7, 2004 10:33 PM
