Bench seat
Old Jan 14, 2015 | 04:36 PM
Shane Carruth's Avatar
Shane Carruth
Bench seat
I'm running into finding a 65 bench seat, so I know they kept the same design for some time. Can anyone tell me how long they used the same style bench seat and yes if it matters it does have the fuel tank in the cab.
Old Jan 15, 2015 | 08:35 AM
tinman52's Avatar
tinman52
Welder User
I used one from a 1974ish truck in my '62....bolted in.....so I'd say '61 through '79 are the same.
Old Jan 15, 2015 | 11:54 AM
daveengelson's Avatar
daveengelson
Will need to use the seat track from the 65 and install them on replacement seats, believe seat track are same from 65 thru 72. Seem to recall from 68 on thru 80's and possibly 90's the seats are same width therefore bench and backs can be mixed and matched. The later model seats are also wider so in event want to tilt seat forward one of the arm rest should be removed. I went with 40/20/40 Lariat seats for my 65, I removed the fabric from the backs and found the 'head rest' was nothing more than thin sheet metal so took a cutting disc and removed them, primarily because I wanted the seat back to set just below the rear window, I also installed retractable seat belts. The topic has come up where member's have posted pic's of their seat configurations, hopefully get additional ideas. Seem to recall thread where member posted pic's with shoulder harness incorporated in the seat?? Anyhow, food for thought??
Old Jan 15, 2015 | 04:04 PM
Roger Carter's Avatar
Roger Carter
Pretty sure the seats will work up through the '96 model year.
The seat in the '66 in my avatar is from a '94 F-150, and my truck still has the in cab fuel tank. The '66 tracks bolted to the '94 seat and when set in the truck, used the original mounting holes in the cab floor.
Good luck
wcs69rat
Jul 17, 2019 01:14 AM
rwrogers
Feb 1, 2014 05:06 PM
otonedog
Sep 29, 2013 07:13 PM
eddiekimberly
Apr 25, 2013 08:36 AM
masterbeavis
Aug 29, 2002 04:12 AM
