F600 brake booster
Dash (firewall) or frame mounted booster? 1969 F600 before serial number E90,001 or from serial number E90,001? Serial number is the last 6 digits of the VIN
C9TZ-2005-F (replaced C8TZ-2005-K) .. Hydro-Vac Frame Mounted P/B Booster / Bendix # 2509140 (replaced 2507376) / Obsolete
C9TZ-2309-B .. P/B Booster Repair Kit / Obsolete
No Ford dealer or obsolete parts vendor has either part number ~ Try NAPA
Applications: 1969/70 F500/750.
F60 = F600 (gas).
C = 330 2V Medium Duty FT engine.
E = Mahwah NJ Assembly Plant.
E26770 = 1969.
F60 = F600 (gas).
E26770 = 1969.
If your brake booster in a "hydro vac" you should put a charcoal filter on the vacuum line as the gas fumes will get to the rubber diaphragm and cause it to fail.
If it has failed, do not rebuild it. buy a new later year one as the rebuild parts use old OEM parts and they only last a year.
I went thru two rebuilt ones before I bought a new one.
I bought mine from,
Midwest Power Products.
1 815 942 0550
$445. Part # 374980N
I bought mine from,
1 815 942 0550
GB SISSON
16
03-13-2014 09:12 PM
P3aflyer
03-05-2008 01:53 AM
jake1251
06-08-2007 05:15 AM
