Door panel trim
Old Jan 15, 2015 | 09:13 AM
scott79's Avatar
scott79
IIRC you can use the stainless steel one's "IF" they are from a Lariat door panel. You might need to make a small cut in the wood grain inserts to allow for the Lariat SS ring to work, I just can't remember!! See the first post rings/tabs!
Originally Posted by rougeriver
I bought a set of the stainless trim last month, thinking I would replace peeling trim on my XLT door panel inserts. They aren't a solution to that problem. The pleated door inserts (on my '77, at least) use a heat-bonded vinyl trim with a chrome Mylar finish, these do not come off. Also, the stainless trim designed for the plain plastic door panels will not cover up where the vinyl trim was, because they were designed to go at the very edge of that opening. The vinyl trim sits inward about a 1/4 of an inch all the way around. The only way these stainless moldings work for the pleated XLT panels would be to make fresh sewn pleated ones, instead of OEM heat-seamed panels.
David
Old Jan 15, 2015 | 09:23 AM
rougeriver's Avatar
rougeriver
Ok. But not the ones shown in the first pics of the red panels (pic #3). Those are the kind I bought. Buyer beware on which kind you get, because you might end up with trim you can't use.
David
Old Jan 15, 2015 | 09:29 AM
scott79's Avatar
scott79
Post#1 and Post#7 (first 3 pics) are the one's that are SS and can be made to work with the wood grain inserts---just going off my "old" memory tho
Ok. But not the ones shown in the first pics of the red panels. Those are the kind I bought.
David
Old Jan 15, 2015 | 03:51 PM
emeraldcoupe's Avatar
emeraldcoupe
You think wood grain is hard to locate, try finding a good set of any of these.
Like Scott said I have never seen the stainless steel trim with the wood grain inlay track/groove. Good luck finding some, have you posted a WTB add in that section
I wish I had a junkyard like that around here!!
Old Jan 16, 2015 | 10:45 PM
papazig4726's Avatar
papazig4726
WTB ='s "wanted to buy". That is where you post a "wanted to buy" thread.
Yes those map pockets are rare too. I have seen them in red, blue and maybe black, but usually they are trashed.
Do not forget to join your FTE state chapter (Colorado right?), here is the link. Great way to get a heads up on parts and good JY locations.
Colorado Chapter - Ford Truck Enthusiasts Forums
Thanks for the info. I'll look at the state chapter. Lyle
fiftyfordfloored
53
Sep 25, 2017 07:48 PM
LARIAT 85
18
Mar 16, 2010 12:02 PM
kidz429
Jan 3, 2009 08:29 AM
