'96 OBD II code P0171
Old Apr 1, 2002 | 07:04 PM
rsrxc700's Avatar
rsrxc700
I am new to OBD II. I had a buddy scan my 96 F-150 4.9l and we got P0171 "System (adaptive fuel)too lean, bank 1"
Help.....where do I start?
Driveability seems fine, but getting around 11mpg in town. Just got the truck and only put about 1000 miles on it, so I have no reference on MPG.
Thanks!
Old Apr 1, 2002 | 07:18 PM
mickelsons's Avatar
mickelsons
I had that code on my 460, and the other bank also. but since yours is inline I guess you wouldn't have that. Mine ended up being that the injectors were dirty and also the DPFE sensor was bad. Before i knew what the problem was I checked and cleared the codes a couple of times and they would come back in about 4 to 5 days.
I had to have Ford do some extended warenty work on mine that is how i found out what this was.
Good luck, hope that I might have helped a little.
Scott
Old Apr 2, 2002 | 09:49 AM
PAUL_2's Avatar
PAUL_2
There are a few things to check , If the air & fuel filters havent been replaced in the last 30k miles , check the fuel psi , vacuum or intake leaks , fuel pressure regulator for leaks , even exhaust leaks ahead of the O2 sensors will cause that code . 11 mpg is on the low side for that engine even city mpg .
Old Apr 2, 2002 | 12:01 PM
slave2dafords's Avatar
slave2dafords
hdbint
Jul 5, 2024 06:16 PM
Whitey Ford
Mar 23, 2016 03:59 PM
papa_jbyrd
Apr 26, 2013 06:10 PM
FlatlanderKW
Aug 4, 2010 04:18 PM
D-man13
Sep 28, 2007 12:33 PM
