Charging problem- alternator problem??
Old Apr 2, 2002 | 05:56 AM
Redneckerson's Avatar
Redneckerson
Here's the problem. I'm driving into work today and have the lights on. I start noticing the lights going dim and the dimming coincides with the amp-meter i.e. the lights go dim when the amp meter goes flat and the little battery light comes on. Would this be a voltage regulator/alternator problem since the voltage regulator is inside the alternator- correct? Time for a new alternator? Any help would be greatly appreciated.
Old Apr 2, 2002 | 09:43 AM
PAUL_2's Avatar
PAUL_2
If the battery & its cables checks out fine then test the alternator . If you do find its dead also replace the regulator & rectifier connecters to the alternator , they have been known to cause more than one electrical fire .
Old Apr 2, 2002 | 10:08 AM
Redneckerson
Thanks for the reply. I never really thought about replacing the connectors and hadn't suspected them as potential fire starters. I imagine these are dealer items. I assume this would be a cut solder replacement? Thanks again.
Old Apr 2, 2002 | 11:40 AM
slave2dafords's Avatar
slave2dafords
paul what years does that apply to? i know i had to put the new connectors on our shop truck ( 90 super duty 460) but was not told about the problem for my 93. also orielys auto parts carries a 130 amp alt that will bolt on in place of the 90 amp that i had on my truck i also have the 302. ok i am gonna stop babbling
Old Apr 2, 2002 | 11:52 AM
PAUL_2's Avatar
PAUL_2
Most all auto parts stores carry those connecters , Ive seen them all over . The Ford ones come with butt connecters etc , Its not hard to replace them at all .
I believe the connecter problem went from the 87 - 92 model yrs . Youll notice that any new alternator you buy at Ford comes with dielectric grease in the alternator connections . It reduces the heat buildup , which caused the excessive heat problem / fires etc . Also the wiring , esp on the 4.9L engines , on some model yrs , was very close to the exhaust manifold & the wiring would melt & or touch & short out there .
Old Apr 2, 2002 | 12:01 PM
slave2dafords
exclent (eww spelling) thank you paul and yes the conversion only took about five minutes while bull *****ing with the boss lol
Old Apr 2, 2002 | 12:19 PM
cmlind's Avatar
cmlind
areoseek
43
Nov 22, 2013 12:03 AM
azu
1983 - 2012 Ranger & B-Series
19
Oct 13, 2007 05:40 PM
luckytruck79
40
Dec 4, 2005 10:41 PM
lottscreek
Electrical Systems/Wiring
Oct 25, 2005 08:00 AM
tolvibman
Mar 3, 2002 10:31 PM
