Door striker question?
Old Jan 12, 2015 | 11:31 PM
FordFETruck's Avatar
FordFETruck
I noticed two different door strikers for older Ford's.
This:
and this:
Now, I have the first ones pictured on my truck. The second version with that stupid extra bracket on it is what they say is the replacement. First off, what is that stupid bracket piece for? and two: are the bushings the same size on both styles? I can get 10 1/2" nylon bushings to replace my originals for $6. I'd just have to cut the washer off and make my own. Or use a big fender washer.
Old Jan 13, 2015 | 03:52 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
The bushing is Delrin (acetyl), not nylon.
My '87 has just the post.
Old Jan 13, 2015 | 05:29 AM
Brad from Oz's Avatar
Brad from Oz
I've just got the straight post, the bushings disintegrated so I just popped on some old hardened garden hose, works a treat
Old Jan 13, 2015 | 07:10 AM
Dorsai's Avatar
Dorsai
At a guess, I'd say that the bracket provides support to the head end of the striker, reducing flex. In turn, reduced flex likely means that the bushing doesn't crack and break off as quickly.
When I replaced my strikers a few years ago I used the original style and have been quite satisfied. I didn't even know there was a newer style until you posted.
Old Jan 13, 2015 | 08:29 AM
Franklin2's Avatar
Franklin2
I got a piece of that PEX plastic plumbing line from the store and did the same thing. I just put a slit in it and pushed it over the pin. My door had a bad habit of bouncing back open about 1/4" when I slammed it. The plastic pipe got rid of that problem.
Old Jan 13, 2015 | 08:43 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Striker Plate
1980/86 F100/350 & Bronco: The original part number was EOTZ-1022008-A
In 1987, Ford replaced it with E7AZ-5422008-A / In 1989, Ford replaced it with E9AZ-5422008-A
EOTZ-1022008-A .. Striker Plate applications / Junkyards: Get 'em off the rear doors of sedans, much less wear.
1980/86 F100/350 & Bronco front doors & F350 Crew Cab rear doors / 1981/82 Thunderbird & Cougar XR7 / 1983 Fairmont/Zephyr front/rear doors.
1983/86 Crown Vic/Grand Marquis/Town Car front & rear doors / 1983/86 LTD/Marquis (Fox bodied mid-size) / 1983/86 Mustang/Capri.
Old Jan 13, 2015 | 12:04 PM
DesertZuki's Avatar
DesertZuki
...The second version with that stupid extra bracket on it is what they say is the replacement. First off, what is that stupid bracket piece for? and two: are the bushings the same size on both styles?...
I was under the impression that bracket existed just to keep the striker from catching your clothes and ripping your pocket or similar.
I got a piece of that PEX plastic plumbing line from the store and did the same thing. I just put a slit in it and pushed it over the pin...
This works. 3/4" PEX 5/8" long.
Old Jan 13, 2015 | 01:46 PM
FordFETruck
Thanks all for the replies!
Old Apr 22, 2015 | 05:27 PM
parr4's Avatar
parr4
Ah Ha! Great photos of the two striker configurations.
I was hunting strikers and came across 'depictions' of the striker with the extra-baggage/modification(#2 in photo). Could not figure what that was supposed to do. My '81 has the #1 type. The sleeve on both doors wore out many years ago. I fixed the problem with some very stiff plastic tubing a pipe-fitter gave me. Did not ask what the fitters used it for, but I suspect it gets nasty chemical solutions run through it. 1/32" thick and opaque. Got 6" of it years/years ago. Still have 3" left....(lifetime supply>my lifetime not my trucks)
Lost_in_tx
Oct 2, 2016 02:56 PM
namxas
Dec 11, 2014 07:24 PM
JoeVR5
17
Feb 16, 2010 08:57 PM
todd jo
Jan 1, 2010 09:33 AM
