My glow plug harness repair
So preparing for turbo install and i figured i would update my gp harness sice im going to move it over to Pass valvecover with Banks bracket. I was gonna make a complete new one but wire was ok upon disassembly. I did squeeze them together a bit and forced them on glowplug to spread for a tight fit I was more comfortable with. Sorry for pics, i still havent figured out how to size them yet.
dorman 85268 weather resistant bullet female connector
crimped then heated with lighter to shrink tubing
almost done
A little wire loom added and on the truck. Piece of cake.
almost done
Received 3,142 Likes
on
that is dielectric grease. it protects the connection from corrosion.
and if you can not find or do not have .157 weather proof connections, you can use the regular .174 crimp connectors and heat shrink tubing with a dab of dielectric grease.
just pinch the end a bit with a pair of pliers to snug them up on the glow plug tip.
on mine, the terminals were fine, but insulation had crumble off ,so I just slid a layer of regular (non-adhesive line) heatshrink on, shrunk it down with a heat gun, and added a second layer. made to take heat, and stays on pretty good. could add some dielectric grease if you want to. If the terminal was damaged, I would either find some uninsulated bullet connectors in the correct size, or insulated ones and take the insulation off and put 2 layers of heatshrink on. Never had much good luck making good crimps with insulated terminals, and these draw enough power, its important.
rosesrfree4u
16
09-24-2020 09:48 PM
tassmannn
05-23-2017 10:00 PM
Tugly
13
05-02-2017 11:48 AM
finallyo3gt
19
02-28-2016 09:43 AM
