Hot Wire
Old Sep 15, 2004 | 07:02 PM
matt f350's Avatar
matt f350
Hot Wire
I need to hook up the 12 volt wire to the 7 way trailer plug on my 1989 F350 so it will charge the RV battery when I am towing. Should I hook the wire to the hot side of the solenoid which would make it Hot with the key off or should it be hooked in with a relay? If so how is the relay hooked up and to what? Also what size of fuse should I use?
Thanks
Matt
Old Sep 15, 2004 | 11:44 PM
SoCalDesertRider's Avatar
SoCalDesertRider
Sure, you can go off the solenoid or the battery and use a 30 amp breaker immediately after it and a 10 gauge wire back to the plug. A cutoff switch is also a good thing to have.
Old Sep 16, 2004 | 09:45 AM
matt f350's Avatar
matt f350
For a cutoff, do you just mean a switch to shut off the power when not in use .
Thanks
Matt
Old Sep 16, 2004 | 11:00 AM
jimandmandy's Avatar
jimandmandy
The factory tow package uses a relay, 30 amp fuse and #12 wire. The reason you can use #12 instead of #10, like in residential wiring, is because the wire is not enclosed in conduit, which holds in the heat. If you do not use a relay or battery isolator you can run down your starting battery.
Jim
Old Sep 16, 2004 | 02:23 PM
Toyman's Avatar
Toyman
If you start your wiring from the switched side of the solenoid you would already be doing the same thing as putting a switch in-line. The breaker is very important so you don't get any back feed surges to your vehicle.
Toyman
Old Sep 17, 2004 | 12:38 AM
SoCalDesertRider
Yes, a switch to turn off power to the tralier plug seperately.
SuperDutyScaler
Sep 6, 2014 12:21 AM
mattjarma
Aug 2, 2014 12:35 PM
1979 f350
1978 - 1996 Big Bronco
Jun 23, 2013 10:22 AM
Beast12
Electrical Systems/Wiring
Sep 5, 2006 06:20 PM
Matt Wilson
Mar 9, 2005 07:05 AM
