2011 F-250 sad state, help.
has a check engine light on , "service advance track" and check 4x4
4x4 will not hold a fuse blows 50 amps regular 20 amps in there i think?
also the motor will Not rev
truck drives fine will keep up with traffic but thats it, will do 150 km/h but takes a long time to get there
floored from a standstill it revs to 2500 fairly normally , it then begins a Very reluctant slow climb to 3400 rpm and thats the peak rpm , if you let off the throttle a hair it drops the revs and you start slowing down. if you use the manual shifting and put too much stress on it in any gear it does the same thing.
I use the truck for work 1600km from home and was forced to drive it home as no transport companies were available and every ford dealership I came across was a week wait for service. truck drove fine whole way home just No power feels like driving a manual in 6th gear all the time I cant get a response out of this engine
no time no money at the moment had to park it
any ideas?
thanks
Hope it helps.
any ideas?
thanks
