trembling on acceleration
Old Jan 11, 2015 | 05:40 PM
conchstew's Avatar
conchstew
My 2000 explorer is trembling when I begin to accelerate. This does not happen when in idle. Any ideas why this is so.
Old Jan 11, 2015 | 09:59 PM
shorod's Avatar
shorod
Which engine does your Explorer have? When is the last time you performed a tune up on the truck, or at least replaced the spark plugs and spark plug wires?
-Rod
Old Jan 12, 2015 | 02:36 PM
conchstew's Avatar
conchstew
The engine is 4.0L SOHC V6. Tune up might be overdue but I did not see any leakage when it is dark.
Old Jan 14, 2015 | 05:15 PM
steve(ill)'s Avatar
steve(ill)
stumble during acceleration is quite often a bad coil or spark plugs.
Old Jan 15, 2015 | 05:08 PM
conchstew's Avatar
conchstew
Hey, Sherod and Steve(III), thanks for the info. It is the wires found a bad leak on a wire last night, changed it and engine running smooth again. However, I wlll have to schedule a full tuneup ASAP as I am way over due. Thank you very much.
Old Jan 15, 2015 | 09:46 PM
shorod's Avatar
shorod
I'm glad to hear you found the issue. Thank you for following up with what you discovered! That helps make forums effective.
-Rod
msasteeler
6.2L V8
13
Nov 27, 2019 09:42 AM
Robbgt
Mar 17, 2017 09:54 AM
Detroit617
Apr 22, 2009 01:57 PM
jdawg11386
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Dec 17, 2003 08:22 PM
JTD1972
Nov 19, 2003 04:20 PM
