Transmission cooler Line
I picked up an early 94 7.3 IDI F350 with 129k miles , Nice solid truck , i been doing major TLC to make it road safe as it sat for long time.
i know from the owner that it had Tranny fluid leak , Tranny shift fine during the short drive to bring it home but loose fluid fast , After inspection i discovered the the leak is not coming from Tranny it self or it's housing , It's coming from the the cooling lines as the lines ( Out and return ) covered by fluid mid way near the right wheel well at least that is what i saw and hoping for .
I called my local part stores to get lines but they don't show them in their system . Does any one one the best after market solution or where to get these line . Or i have to get them from the Stealership
I am going to investigate farther more into it today
Received 3,181 Likes
on
on
they're 5/16 line oem.they didn't become 3/8 until the name change to 4r100.however 3/8 lines is an upgrade that wont hurt anything.there's a bit more to perform the whole upgrade but no point in details unless interested (not an upgrade worth anything imho unless you upgrade the internal pump to the '95+ high volume.)
in summary.either or 5/16 or 3/8 will do the trick.good luck.hope that's all it is.
It was a long afternoon but ended up with great result , Resealed all injectors, New fuel /Water filter , Fresh fuel , primed all the lines and we got nice running 7.3 IDI with Zero diesel leak .
Make sure you disconnect the ground if you ever get to work on any of these suckers and have to remove the glow plug relay or the (hot ) lead will touch something ,ask me how do i know
Added more ATF fluid and without even the Eng running i discovered pin hole on one line and the 2nd shaved from rubbing on the one is leaking , the leaky lines coming from the area near the starter . I guess the pressure increase inside these lines when the internal valves inside the transmission move
I wont be town heavy at all , All will be Hwy driving and loaded bed . Should i cut the bad section and use rubber ATF hoses or what is the best solution than re do it all
I also have Sidewinder turbo by banks Power in place , With single exhaust Gauge inside , Where can i get the triple gauges set up to monitor boost , exhaust , Tranny Temp ..Etc
on
on
with the above lines being new i started to drive the truck and noticed another issue with the ATF coming out from the bell housing when it reaches the Op temp .
Most likely Pump seal or bushing need replaced along with the seal, So the truck at the shop to get the tranny pulled to replace the $8 part and hope that the TC grooved neck is good .
Due to the weigh of this giant Tranny , no access to heavy duty trany jack i choose to send it to the shop as much as i hate it . I am going to install the Big 6.0 Tranny cooler or after market large cooler any thing else to keep in mind
Sounds like youre pretty well on top of things. One more thing to consider is a tugger shift kit, since you already have it at the shop and its pulled, wouldnt take much to put it in while the fluid is dropped. A good converter would help as well, but are pretty spendy. Maybe someone above can chip in on how much theyre really needed at stock power level.
