Transmission cooler Line
My plan was to find 6.0 Tranny Oil cooler if there is a better option out there i would like to go with it .
hairyboxnoogle what brand did you go with if you don't mind , I will be hauling race trailer with this truck and don't want to take a chance
I just grabbed it out of the junkyard, cant even remember what it was on. If you run the trans line to the radiator, then to the aux. cooler back to the trans, you will probably be fine. If you really want piece of mind, buy a trans temp gauge. Ideal is 165* Normal operating temps should be between 150-180, i wouldnt go over 220 if i could help it, 240 is very bad.
clean oil
Just had my c6 overhauled. Kitted, torque converter set for diesel stall, towing bands, clutches etc. Been a bit of a granny getting past distractions, but back on it now. Tranny shop would offer no warranty if I re used any components in the cooler system. So new cooler with t-stat, lines and magnetic filter. Cooler in core blanked off, old external cooler removed. Cost? Extra 300? I like the filter the most never thought about metal particles before but now that it has been pointed out I should have.
on
I've never had the need for a fan on a trans cooler but had the idea years ago to use the cooling fan from a motorcycle. I did some road racing years ago and everyone removes the fans and a lot of them end up on ebay. Go to ebay and search "gsxr fan". Other tags for cycle models are cbr, r6, r1. All are 12volt systems.
Funny i just removed my Race R6 fan and it ended up on E-Bay
![Big Grin](images/smilies/biggrin.gif)
on
The older I get, the faster I was.
#28
That's kinda funny, I've noticed your username before and figured you were into roadracing but didn't notice it was you posting here. I had an r6 for a short time, just did track days with it, raced a fzr400 for one season then got a sv650 that I ran WERA and CCS at Summit Point, VIR, and went to the WERA nationals at Road Atlanta once. Good times. Want to buy a vs that's been sitting a few years?
![Okay!](images/smilies2/thumb.gif)
I ran with few racing team from Up NJ and PA on the R1 , 954, 929 and my beloved Rc51 and Ducati during the CCS but never jumped on the WERA class. Crashed hard on Beaver Run race way 7 years ago on the R1 as my rear wheel got touched on the back during Moto Cup race sending me High sided to the sky before i moved to NC.
Finally finished building an R6 to run that class and here comes the 7.3 IDi to take the race machine and the crew every where . Our Race team AKA ( T&R racing ) will be doing endure race and like you said the older we get the fast we are( You get wise and see the race line much better ) rather the twist the throttle hard
![Laughing Grin](images/smilies2/biglaugh.gif)
Been at Summit so many times before i moved to NC from PA , Most my tracks near NC will be VIR, NC bike and Carolina Motorsports SC. However during the Endure race i will be at Summit
SV are a cool machines i am all about the Twin power, I spoiled my self with a Ducati S2r 1k for the street just for the torque/power . once you race a 2 wheel it's impossible to get it out of your system. Hopefully you get one sooner our later to get you out there
#29
cooler fan
bashby
____
I guess I could have explained better in my previous post, I have a large tranny cooler installed, in front of the radiator core, which I have fitted twin electric cooling fans to. My acknowledgement of FORDF250XLT's comment re low speed work/idling and mention of electric fans with a manual override switch could have confused due to possibly an inexact desrciption. My old slugger is 2wd and a tow wagon mainly so gets very little of the other work.
____
#30
Talked to the shop this morning every thing went smooth so far with replacing my Pump seal , Rear main looked great , But when the guy returned from the Test drive he notice the Over drive flashed . I took the thing to them running perfect with no codes beside Pump seal .
crossing my fingers it's only something simple , dirty wiring, low oil or something that they have to worry about it no me . He said he will scan . The curiosity getting the best of me.
