Diag trouble codes
Old Jul 20, 2003 | 11:50 PM
FyreLyter's Avatar
FyreLyter
Diag trouble codes
Hey, I took my truck to a shop to get it diagnosed for a check engine light and the tech told me that these two codes came up...
po231 and po505
my truck doesn't idle very well at all, in fact when I start it it dies immediately. If I give it steady throttle when I start it, it revvs up and down repeatedly. Now I changed my fuel filter, due to it being pretty clogged, and the tech said that was probably the reason why the po231 code was up (fuel pump circuit high). The pump was trying to work extra hard to pump thru my clogged filter.
Everything else checked out ok according to the tech, and it passed smog with flying colors...
He thinks it might be the fuel pump going bad, or the muffler being clogged enough to create backpressure...I don't know, but it would mean more money if he tore into it to check more fully.
Anybody out there have a similar problem? oh yeah... 98 XLT 2.5L manual SC
thanks..
Old Jul 21, 2003 | 12:09 AM
mrwizard's Avatar
mrwizard
Diag trouble codes
Did the 231 code go away after changing the fuel filter? The 505 code is "Idle Control System Malfunction".
A muffler isn't going to get clogged. The catalytic converter could be bad, but that's easy enough for a muffler shop to check out. If it's bad, it should be covered by something like an 8 year warranty, so check with your dealer if that's the case.
Old Jul 21, 2003 | 05:02 AM
FyreLyter's Avatar
FyreLyter
Diag trouble codes
If my Cat Convertor was bad, wouldn't it come up with a code or something? And would it pass smog controls for CA?
Old Jul 21, 2003 | 05:28 AM
FyreLyter's Avatar
FyreLyter
Diag trouble codes
Oh yeah, about a week and a half ago I used Prestone Fuel Injector cleaner with that Boost octane booster mixed in it. Would that have made any problems worse? All this happened a little while after I used that...
JacoFordCummins
Engine Swaps
45
Nov 4, 2020 09:09 AM
Flooder305
1997 - 2003 F150
Sep 3, 2016 06:23 PM
JOHN2001
Mar 23, 2014 01:03 PM
DeereTech05
6.4L Power Stroke Diesel
24
May 9, 2010 01:50 PM
smythcounty
Oct 21, 2009 06:36 PM
