OIL ON GLOW PLUGS
OIL ON GLOW PLUGS
Just replaced glow plugs 2 and 8 had codes.Pulled out only to find oil on them.Was this caused by the under boosting turbo I just replaced About 3 weeks ago.Or I,m guessing valve seals or rings in those cylinders.Motor only got 42k its a 04 550.Just replaced number 3 injector day before this did same one 5 weekd ago dealer warrantied the injector.Havn,t had any time to drive since I installed glow plugs other day.When the turbo was underboosting I did see blue smoke.That has since been gone.Just wondering If i got a major problem coming next.I have been pushing coolant out the cap for the last 4 months also.Not a lot but there is residue up there.
Yes but isn,t it inside the combustion chamber?That is what had me worried.The glow plug is in the chamber why is there oil in there?One would think piston ring problem,Valve seals/guides dropping oil no?
If you would have ohmed out #2 and #8 glow plug circuits directly at the GPCM connector, it would've saved you the hassle of changing out #2 and #8 glow plugs. For what it's worth, it wouldn't be the first failed GPCM that set only specific glow plug circuit codes like in your case.
With my failing memory that is a good possibilty Rusty and with no factory training on the 6.0 and no manual maybe you don't have to remove the valve covers.
Even with cataracs in both eyes crewdually's photo shows the glow plug inside the rockerbox. Also the only time I had to remove a glow plug on a 05 was # 7&8 on a non ford chassie. What I call a bread truck with a dog house not really a van but almost as bad.
Maybe for me it was just easier to remove the broken glow plug end. So I wrongly assumed it had to be done on all.
You would think after all these years I would have learned not to assume anything.
Since I have always considered Cheeseit and MChan my masters on the 6.0 I will have to re-elvaluate my position on this.
I hate typing so I try to include pictures since as the saying goes it's worth a thousand words. With that said, I'll add a few more words.
For the confusion of access to the glow plugs, remember the harness ends. They are not under the valve cover. They are below the cover, so there's no need to remove them. When I have to remove glowplugs, I do everything I need to do through the wheel well. I hope this clears it up.
If you notice I personally have a 2005 and work on 6.0's. If you still don't believe it, go look for yourself.
