Old George (mini) Build Thread
Thanks! It looks like yours in the perfect candidate for the same style. Looks Good!
The first one is for the cowl vent install. Here's a few photos first:
And here's the link to the thread:
https://www.ford-trucks.com/forums/1...-tutorial.html
And the next one is a12v wiper motor install:
And here's the link for that:
https://www.ford-trucks.com/forums/1...d-pile-on.html
Most recently though we've been re-wiring everything, such as: Headlights
Running lights:
Taillights:
And Turn signals, to name a few.
Even the dog loves the truck enough to groom it.....
These are all works in progress, so no finished products. I'll have more photos and better explanations (and a few tutorials no doubt) when we start to button things up better.
This week we're back to the grind stone with work/school/both kids in sports.etc, but we managed to get a few things accomplished.
I have a line on some T5s so I wanted to know for sure what gear set I had instead of getting close with the spinning the back tires and counting the revolutions of the drive shaft. I also need to replace the fluid:
Chocolate milk....... so good
I couldn't figure out how to get the whole assembly out, so I took off the pinion gear so I could at least count everything
I have yet to 100% ID what I have other than I know it's a Ford 9".
From what I understand, a sure fire way to tell you have a 9" is that you will not be able to attach a socket to the bottom 2 nuts. I used this ratcheting wrench. There is not enough room to hand tighten the nut and then slide on the wrench, you have to put the wrench on first , then hand tighten the nut, then wiggle the wrench over the nut.
While I was prying on the case to get out the fluid and attempt to remove it I apparently stripped a couple bolts...... not enough room to get your handle in there so I had to improvise. Lets just say it took a while....
It turns out I have 2.75 gears back there,and so I'm currently trying to figure out if/what to change to.
I love these 3M connectors with the heat shrink and adhesive!
I chose not to repaint the needles so as to maintain the original faded theme.
Thanks Doug! I've been following your build as well (lookin good). I did a little tutorial, not a lot of detail, but it may help some concerning my ebrake install. Here's the link:
Keep up the good work, and hit me up with any questions.
Been soaking these in vinegar
Here's what happened after a couple days
This is about a week
Had to do just a bit a grinding to fit in my new turn/running light
All cleaned and painted
A little tip: as soon as you take something out of vinegar it needs to be rinsed and either dried/painted or covered in oil right away or it will start to rust
Installed a 4 position headlight switch from Painless. It's a little loose as far as finding the positions, but so far it seems ok. I had to do some bending and tweaking to get it to fit.
Testing the headlight/harness:
Another bone head mistake I made was trying to test the H4 headlights with relays using a 6v battery I had laying around..... use a 12v
Gauges are in
Lights even work
Love the heavy duty headlight harness with the H4 bulb. Amber running light #1157 with clear lens cover
Thanks to some good fellas on here I'm running a fuse box, but I wanted to find a nice place to hide it that I could still get to it when I'm too old to stand on my head and look under the dash. I wanted to put it right next to the driver door and I thought an old tin box would be cool to place it in. I searched and found some old emergency kits that Ford made but they were pricey, so I found a fairly old Medical kit. It was plastic however and I was telling a buddy about what I wanted to do. He had bought some old medal med kits at an estate sale and asked if I wanted to use one of those:
The one on the left was the first one I found,and the one on the right my buddy gave me (for the price of a beer that is)
Should work pretty good.
Stay tuned.....
So I got 1/2 day off work. Guess what I did with all that extra time. You guessed it! Got some misc things wired like gauges:
Yikes!
Help....
Put the fusible links in at the Alt and Solenoid
Then I got started on the fuse box:
Here's where it will go. Notice the 2 magnets from Lowe's. I was going to use those to mount it so I didn't have to put anymore holes through.
Then I remembered I had this Otter Box with a nice strong magnet that you can mount to the box:
Once it was mounted I covered it with tape because it picked up every single piece of metal in my garage/house/block. Do that first if you follow suit.
Didn't want to get rid of these hanger tabs, but they were in the way:
I wish the box was more like the plastic one in the sense that it is deeper and has a shallow lid. That would have given me more room for the wiring on the inside. Here's how I ran the wires in though:
Middle is for the power and the outer 2 will feed the box on either side.
Mock up:
Wiring started:
I had to bend the tabs up a bit so they would clear the sides. A little tight, but not bad.
The best thing about using the magnet is that you can move it to a more convenient spot when you need to change a fuse or work on it:
Here will be it's final resting place. Still need to dress up wires, but you get the idea:
It rests on that support,and I don't think it will ever fall off. If it does it won't go far anyway.....
Someone let me know if you think the magnet will affect anything concerning the wiring. I know magnets can do weird things, but I've never heard about it affecting electricity. Thanks!
