Turn Signal Switch
Old Jan 9, 2015 | 12:06 AM
Shadowrider123's Avatar
Shadowrider123
Turn Signal Switch
On a 64 F100 the turn signal switch has bullet connectors that plug into a "jumper harness" that then connects into the wiring harness.
Is this "jumper harness" available?
A search turned up p/n C1TF-13A329A, but I cant find a picture and the only description says "turn signal jumper harness".
Im asking because I can disconnect the jumper harness from the wiring harness, but I don't think those bullet connectors are coming out of the jumper harness without destroying it.
Old Jan 9, 2015 | 01:05 PM
William's Avatar
William
I GOOGLED that PN# and a company called C&G shows they have it for around 46 bucks. I often do a search for these obscure Ford parts and I am often lucky. JMHO!
Old Jan 9, 2015 | 02:03 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by William
I GOOGLED that PN# and a company called C&G (Is this it? C&G Ford Parts, located in Escondido CA) shows they have it for around 46 bucks.
Parts catalog sez inre to C1TF-13A329-A: Improvise from B6A-14296-C .. 16 Gauge Bulk Wire.
No one on PartsVoice.com, rearcounter.com or the D2D (Dealer to Dealer - Ford dealer parts locator system) has any.
I also googled C1TF-13A329-A .. came up with a different source: Melvin's Ford Parts in GA
T/S switches of this era consists of loose wires that plug into a connector. The "Ford tech" EZ was to change these switches is:
Cut the colored wires off just above the connector, leaving just enough that the colors can be identified. Tape the wires together, tie a long piece of heavy string to them.
Pull the switch from the column, then tape the new T/S switch wires together, tie the string to them. Pull the string from the bottom of the column, the wires will feed down without binding.
Now pull the cut off wires from the connector, install the new wires.
Old Jan 9, 2015 | 07:09 PM
Shadowrider123
That's how I want to do it, except the wires are not going to disconnect from the connector. I already destroyed one trying to get it disconnected.
I think the jumper harness is a flat 3 wire trailer connector. Im going to see if it is.
The other problem is ALL of my TS wires are Caribbean Turquoise. The PO want much for using tape.
Old Jan 10, 2015 | 09:55 PM
KO1960's Avatar
KO1960
The wires have a metal tab that can be collapsed. Push on the tab while pulling the wire. Worked for me. Good luck.
Old Jan 10, 2015 | 11:07 PM
TxStang2010's Avatar
TxStang2010
Snap On makes a little tool to remove connectors from the housings , sure makes it a breeze to do .
Old Jan 11, 2015 | 10:03 AM
Shadowrider123
64's do not have the same switch or connectors as 65-66's.
64's are bullet connectors that do not have a housing, each of the 6 wires is connected to (2) 3-wire flat connectors that look like trailer connectors. Those flat 3 wire connectors connect to the harness with a matching connector and to the turn signal harness with bullet connectors.
Old Jan 11, 2015 | 01:55 PM
TxStang2010
there are called SAE connectors , a few online places sell them in pigtails from 2 conductor all the way to 8 conductor .
okie trucker
Sep 11, 2018 10:40 PM
ricku
20
Dec 23, 2005 09:26 AM
IAv10
All Things Towing
Mar 24, 2004 09:58 AM
JMR
Oct 2, 2001 11:49 PM
F10067weber
Mar 25, 2000 11:49 AM
