Rear hatch light switch
Old Jan 14, 2015 | 01:34 PM
mb_01sc's Avatar
mb_01sc
Originally Posted by harley4jcs
To All with an interest: The WD-40 seems to have corrected the issue. The back hatch has been used 50 times or so after a good spraying ON TO THE LATCHES INSIDE the door with a 100% NO-FAIL rate.......
Glad that worked!
Old Jan 14, 2015 | 05:35 PM
EXv10's Avatar
EXv10
So does anybody know for sure where this contact point actually is back there so it can be addressed?
Old Jan 14, 2015 | 06:08 PM
Magnus E's Avatar
Magnus E
I know nothing ... But I post anyway
Old Jan 15, 2015 | 09:26 AM
Vince79vette's Avatar
Vince79vette
I have the same problem. And it also interferes with my aftermarket alarm system. It say when it goes off that a door sensor was tripped and i know its the back since its the only one that gives me problems. Love to know how to fix it
Old Jan 15, 2015 | 09:31 AM
harley4jcs's Avatar
harley4jcs
"To All with an interest: The WD-40 seems to have corrected the issue. The back hatch has been used 50 times or so after a good spraying ON TO THE LATCHES INSIDE the door with a 100% NO-FAIL rate......."
Old Jan 15, 2015 | 09:32 AM
Vince79vette
Think i found where its is. And part number too. Look at post #6
http://www.thedieselstop.com/forums/.../topics/103767
Old Jan 15, 2015 | 09:34 AM
Vince79vette
Thanks man. But for 26bucks i will fit it. Cant have a alarm going off random like it is now.
Old Jan 15, 2015 | 11:01 AM
harley4jcs's Avatar
harley4jcs
So you think that after the truck is closed up & all is well THEN the back hatch switch unmakes itself as to set of the alarm ?? That would mean that just some time in the night all my lights would come on ...That never happens on any of my trucks...when I get them to make up (slam method) they stay that way till used again. Never had one unmake itself while driving around either. look at post #9.. Seems to be a valid fix..$26X2 but I don't think that is the problem your having with your alarm ??
Old Jan 15, 2015 | 11:05 AM
EXv10's Avatar
EXv10
Seems to be a pattern in here........lol
Old Jan 15, 2015 | 11:07 AM
EXv10's Avatar
EXv10
That wd displaces moisture but as soon as it dries up it will be back and maybe worse because now it probably attracted dirt.
Old Jan 15, 2015 | 11:12 AM
harley4jcs's Avatar
harley4jcs
THIS IS JUST A TEST You may return to your scheduled programing ...
Old Jan 15, 2015 | 11:36 AM
EXv10's Avatar
EXv10
Without going out in the freezing weather; he never said WHERE these switches are. Exactly where are they? I have never seen so much vagueness on such a simple subject.
Old Jan 15, 2015 | 11:46 AM
  #28
Vince79vette
I think its the sensors because the light did come on one night. And its only happening when it gets cold out
Old Jan 15, 2015 | 11:53 AM
  #29
harley4jcs's Avatar
harley4jcs
Do your lights come on if the alarm goes off ?? Chick or Egg question.
Old Jan 15, 2015 | 01:43 PM
  #30
robert_l_ross's Avatar
robert_l_ross
This might help visually...looks like it's attached at the latch?
http://www.justanswer.com/ford/33e6b...art-xxxxx.html
