you need to look at the TDS technical data sheet, booth are made out of different resin and booth dry to a different thickness, also cover wise the regular vs pro, covers more area but is not as thick once dry as the pro covers less and has a nice build. if you just top coating on a existing top coat go with the cheaper one but do your best to get the surface clean, otherwise with time will end up peeling off.
Thanks Josh. I read the TDS but frankly did not understand the differences. I will use the Pro version to spot fill the areas I repaired (1 can) and then re-coat everything in "amateur".
