Tonneau selection help please
For now, I'll just start with the Bakflip models. First, from a construction standpoint it seems there are aluminum, composite, fiberglass - what is the real differences? Their site seems to assume you already know why you would pick one over the other. I don't know that I care much about what is made of, I just want it to be secure. So going off that, it seems like my top two choices would be the MX4 or F1 because of the ability to open/close the tailgate with the rear panel up or down. And then, of the two the MX4 seems to make a bit more sense to me because 4 panels vs. 3 allow different depths of the open bed while more easily tucking under the high mounted center cab light.
Lastly, I want something waterproof, but from appearances all the Bakflip models use the same/similar design so maybe I need to look at some other brands to understand the differences and pros/cons there. Otherwise, it seems like the MX4 fits my needs if I'm going with a Bakflip tonneau. So, are there some construction or materials differences I'm not understanding or need to take into account? If I should look at other brands, what's the primary reason - better construction, other features, better weather resistance, better security or lower price?
Thanks in advance for the help and suggestions. Oh, and I know some folks are a big fan of the Line-X version of the F1 (LXP), but I asked them for a quote so I could do an apples-to-apples and they told me the LXP doesn't have a version for the 8' bed.
- I would call the MX4 water resistant, not waterproof. Seems to me that unless the tonneau wraps completely over the bed, like some hard caps, they will leak some water, That said, the MX4 is pretty tight and water has not been an issue, but I get a lot of dust.
- One thing I like about the MX4 is the ability to completely fold it up so you gain the use of the whole bed. It works pretty slick.
- Security is iffy at best. Theoretically, you lock the tailgate and the load is secure. The problem is that it wouldn't take much to pop the top with a prybar or large screwdriver. The latches are a pretty strong plastic, but not invincible.
- Another plus on the MX4 is that the tonneau sits between the bed rails. That allows you to add tiedowns like the Bullrings (pretty handy IMHO)
- I could never figure out pricing. I bought directly from Bakflip. My experience has been that you can negotiate price, and I got three different prices each time I called. That said, I got a pretty decent discount.
- I think the mat finish looks good.
I like the flip covers outside of that. I like the Under Cover Ultra Flex better than any of the Bak Models. It has some design tweaks that are a little better. But they only make 3 panel covers so may not make one for a long bed.
On my current truck, I ended up with the Bak Revolver X4. Doesn't take up bed space, and allows me to see the gooseneck ball. But have had Bak flip covers and the Ultra Flex in the past. Both good covers.
- The difference between the MX4 and F1 is 2 things, one is matte and one is glossy. The matte one is highly UV resistant, the glossy one is highly hail resistant.
- Don't expect either to be water proof, I tested them both and they are not, close but not 100% (they both allow some water in at the tailgate corners.
- The panel count depends on bed length, 3 for shortbed and 4 for longbed.
https://www.agricover.com/hard-tonne...hoCPHcQAvD_BwE
If waterproof is an imperative, your best bet is probably a solid tonnueau, however I would be interested in hearing from anyone that has a solid cover with regards to how it works with a power tailgate.
- By waterproof, I mean to the best standards available in folding tonneaus. A solid cover would not work for me at all (almost any time I need to pack gear, it usually includes bicycles and our TT doesn't have a rear hitch for our bike carrier, nor do I like loading 4 bikes on the carrier anyhow).
- I will have the factory spray in bedliner, so blowing or washing out dirt and dust is no problem at all. I want to be able to store things like camping gear with an assumption everything will be dry on arrival, permitting a few drops to leak hear and there. Once I learn the most likely ingress points, I'll keep anything water sensitive away.
- I don't think I mentioned it as a requirement, but I want something that opens the entire bed up without having to remove the tonneau. So folding covers that don't fold up against the back of the cab are going to be a no-go.
- The Bakflip specifically listed which do and which do not allow tailgate open/close with the rear section down. I didn't see that on the Lomax, for example, but I may have missed where they specified it does/doesn't work that way.
- Thanks for the 3-panel vs. 4-panel understanding. They didn't have a demo video for the F1 and the stock photo showed a 3 panel even after I specified my 8' bed.
- I don't currently need to see 5r or GN hookups, although I did get the fifth wheel prep. I assume it would work just fine with the way the MX4 folds up to the cab.
Thanks again for all the first hand knowledge.
One thing I really miss from my solid cover on my F150 is when it's pouring rain I can open it up and grab what I need without soaking the bed on the tailgate end. Just food for thought here.
1- Waterproof. Very very little leaks in some corners. Maybe 1/2 oz total
2- see #1
3- F1 folds up against the rear window protruding maybe 6” into the bed.
4- newer BakFlip F1has a seal that allows you to close cover before tailgate. The web site has not been updated.
5- My F1 is a 4 panel on my 2017 F350 Short Bed Truck .
6- I always Tow with one panel down. With my Andersen Hitch I can see the Andersen Ball and coupler in the top rear mounted camera. And that’s with one panel down. See picture below. The red rod is used to locate where to stop when I back up to the trailer pinbox.
NOTE: The FRG F1 is showing some weathering on the top side paint due to sun exposure. BUT you can hit it with a hammer and it doesn’t dent. I’ve seen MX4 tops with hail dents. Not an issue with the F1.
I have a F1 BakFlip.
2- see #1
