Bearing Hub Replacement Question
Old Jan 6, 2015 | 01:09 PM
Submarine Docker's Avatar
Submarine Docker
Looks like I need to replace driver's side front wheel bearing hub due to bearing starting to fail. I have a rotational rumble that is directly related to speed and is getting worse. It occurs in both 2WD and 4WD. Things done so far: new tires w/ alignment, locking hub maintenance, new brakes - rotors, calipers, pads and hoses, new shocks, front axle turns freely and u-joints look good. I think this all started when caliper froze up on that side or it could just be the mileage (281K). Rock Auto seems to have the best prices. Any recommendations as to Timken or Motorcraft? About $100 difference in price.
Thanks,
Jim
Old Jan 6, 2015 | 01:28 PM
Tedster9's Avatar
Tedster9
I'm probably missing something, why does the hub have to be replaced if the bearings are bad? That sucks.
Old Jan 6, 2015 | 01:48 PM
Christof13T's Avatar
Christof13T
The hub bearing on a 4x4 is a pressed together, sealed unit.
I work as the milling department head of a fully tooled cnc machine shop...
We do not have the capability to rebuild a hub unit at my shop.
Not much of a chance for the layman to accomplish such a feat in his home garage...
Old Jan 6, 2015 | 02:01 PM
Tedster9's Avatar
Tedster9
Ouch! More expense, then.
Old Jan 6, 2015 | 02:04 PM
Christof13T
Depends...
In a jam... i was able to locate a chinese hub off ebay for 45$.
It has been holding on so far and has been almost a year...
Better believe as soon as i could afford it i had 2 made in u.s.a. hubs ordered for "just in case".
Old Jan 6, 2015 | 04:21 PM
ebbnflow's Avatar
ebbnflow
I ordered the Timkens with a 3yr warranty from autozone for about $150 each. It was the only place I could find that offered 3 years. Amazon and others say only 1 year. The motorcraft ones were too rich for my blood at about $260 IIRC.
Old Jan 6, 2015 | 05:27 PM
jgilrfr's Avatar
jgilrfr
make sure the threads on the studs are correct on the new one,some arecoarse and some are fine
Old Jan 7, 2015 | 12:57 PM
FSJ-EARL's Avatar
FSJ-EARL
I picked up my Timken hubs / bearings at the local AutoZone and they were pretty reasonably priced. Much cheaper than the Motorcraft and a better quality, at least in my experience.
Old Jan 7, 2015 | 01:36 PM
retiredsparky's Avatar
retiredsparky
Jim, if you buy locally you have the opportunity to manually turn the hubs to check for too tight torque from the factory. I bought two Timken bearings. The first one had a "ratcheting" feel to it when turned by hand, indicating too tight a factory torque. The second one the outer stub support needle bearing had been pressed to tightly into the hub causing the needle bearings to lay slightly sideways and preventing the needle bearings from spinning. So I asked the auto parts store to bring out two more for inspection. Both of them were ok and still work after 15K miles.
Larry
GlenPxC
Jan 23, 2019 11:24 AM
bronco6767
Apr 15, 2016 11:44 AM
Patchy 73
Australia Chapter
May 3, 2015 06:29 AM
elwood9270
1997 - 2003 F150
Jan 18, 2014 09:14 AM
operator414
Apr 12, 2008 01:10 PM
