engine help
Old Jan 5, 2015 | 08:37 PM
dbeast1113's Avatar
dbeast1113
engine help
Hey guys,I bought a newer 302(92) and it has power steering and a/c. Since my truck doesn't have that, could I take them off? If so, in what way do I put the new belt? Thanks.
Old Jan 5, 2015 | 08:43 PM
Osiyo59's Avatar
Osiyo59
Not 100% sure but I think you may need to switch from a serpentine belt back to a V-groove style pulley set up if you eliminate both the A/C and power steering pump . If so you will need to switch out the water pump as well. The pump for the serpentine belt rotates opposite direction of the standard V-groove.
Old Jan 5, 2015 | 09:18 PM
yellodog's Avatar
yellodog
i have seen an a/c delete pulley setup, but i don't know what you'd do about the p/s pump. if you have to fab another dummy pulley setup, you might be better off going back to the v belt system. either way it's alot of extra work.
Old Jan 6, 2015 | 02:24 AM
Shadowrider123's Avatar
Shadowrider123
Go to a Mustang board and ask the same question. This is common mod for the vintage 65-73 guys.
They have the procedure down for the easiest and lowest cost.
Flatbed351
Feb 22, 2013 06:11 PM
Tomboy
Oct 25, 2012 06:54 PM
rblaine9000
Feb 24, 2011 07:40 PM
hollygreenman
Oct 21, 2010 06:13 AM
ferguson777
Jul 22, 2005 08:44 AM
