Engine light came on over the weekend, then went off and back on and off. All orange. Called My ford dealer this morning and they had me bring it down there for the day. Drove me home then picked me up this afternoon when it was done. Also had oil change and fuel filter change.
Scanned for codes found P202D Reductant Leakage and P20E8 reductant pressure to low found tsb 11-12-03 followed tsb and replaced reductant tank pump cleared codes preformed koer glow plug on demand self test passed and preformed reductant leakage test passed road tested to verified repair ok at this ti
One of the best things about my dealership, beside great customer service and a very friendly staff is that with ANY vehicle purchase you get FREE oil changes for LIFE!!!!!!!! Nor do they try and up-sale you something on the side. They will even pick up your vehicle and drop you off a loaner if need be.
I've been quoted $300 just for an oil change, which I politely denied.
I always pay $125. I've totally thought about doing it myself, but when I was looking at buying the Motorcraft diesel oil it would cost me about $120, which makes it make no sense. Especially when I need the filter too.
the local dealer here charges me $92-98 depending on a coupon or not for Diesel oil change.. and saves a sample in the blackstone bottle when I ask.
It a easy oil change. I get it done for less then 100 buck with ford a ford filter and about 15 minutes.
On the fuel filter biggest clue I can give you is go slow and make sure you tighten the lower fuel bowl all the way before starting the truck. Also use a strap wrench on the lower bowl.
