Traded for a DRW
Old Jan 6, 2015 | 01:42 PM
  #31
Big-Foot's Avatar
Big-Foot
Originally Posted by bryced15
Thanks for all of the compliments! Really enjoying the truck.
I was poking around on it last night and got to looking at what was going to be involved with putting the airbags on this one. Last truck had the B&W gooseneck hitch in it. This one has the ford factory gooseneck in it. It looked to me like I'm going to have to take the side plates off of the Ford hitch to access the big holes in the frame for the large bolts that go on each side for the airbags. I didn't have to do that on the old truck with the b&w hitch. Is there an easier way that I'm missing?
When I ordered my truck, I ordered the factory fifth wheel prep. There was a different option code for the factory gooseneck prep. What's odd though is that the fifth wheel prep appears to have a socket for a gooseneck hitch as well..
Old Jan 6, 2015 | 01:45 PM
  #32
sdetweil's Avatar
sdetweil
yep, only one hitch thing.. you just didn't get the GN ball kit..which is separate
Old Jan 6, 2015 | 01:49 PM
  #33
senix's Avatar
senix
I got my ball off of amazon if I recall. Hitch from the dealer as part of the deal.
All a once piece unit.
Old Jan 6, 2015 | 01:58 PM
  #34
bryced15's Avatar
bryced15
mine has the gooseneck and 5th wheel prep. 5 holes. I am wondering if I have to remove the plates from the prep under the bed on the sides of the frame in order to put airbags on it. Looks like a lot of extra work that I didn't have to do before.
Old Jan 6, 2015 | 02:01 PM
  #35
golfmedik's Avatar
golfmedik
I believe there is a different part number for the trucks with the factory hitch installed. If your bags were Firestone, you could call SD Truck Springs and just order the new brackets for the same bags. That is what I did mine across model years. I am not sure if AirLift does the same. You could call SD and see though.
Old Jan 6, 2015 | 02:02 PM
  #36
golfmedik's Avatar
golfmedik
There are two whites in the Ford Super Duty truck line-up.. The Platinum is a Tri-Coat white with a lot of pearl in it and it is much thicker paint and more resilient.. It is pretty special and as far as I know, it's the only tri-coat paint color..
That is the color I have and I absolutely love it!
Old Jan 6, 2015 | 02:05 PM
  #37
bryced15's Avatar
bryced15
Ok I'll try that thanks!
Old Jan 6, 2015 | 02:11 PM
  #38
PlayersZ28's Avatar
PlayersZ28
Congrats on the "newer" truck I like my fat *** F350 (only for trucks, not women). I have the same hitch setup but haven't done bags yet, nothing heavy enough to tow right now that needs them. Next summer probably though.
Old Jan 13, 2015 | 06:35 PM
  #39
bryced15's Avatar
bryced15
Installed the Bakflip VP tonneau cover and the Duraflaps. Here's some pics.
Old Jan 13, 2015 | 07:26 PM
  #40
sdetweil's Avatar
sdetweil
Nice! I'm thinking about front flaps. Have rears
Old Jan 13, 2015 | 09:29 PM
  #41
Ferguson65's Avatar
Ferguson65
You don't have to remove the side plates. There is just enough room to sneak the nut in there between the side plate and frame. I've got the airlift 5000 ultimates, and all I did was drop the spare for some extra room, though jacking it up and removing the rear wheels would help too. Word of caution, the bolts that came with the airlift kit were a hair too long and bottomed out on the side plates, I ground them down a bit so they did not interfere.
Old Jan 14, 2015 | 01:14 AM
  #42
Sailor Roy's Avatar
Sailor Roy
Veteran: Navy
Active Streak: 30 Days
Originally Posted by FalcoDog
Beautiful truck!
I can not own an F350. It would too hard for me to fight the urge to just run over lesser vehicles that get in my way.
Good luck with it!
What is wrong with that..........
Old Jan 14, 2015 | 05:46 AM
  #43
Big-Foot's Avatar
Big-Foot
Hmmm... Maybe an extra flat washer under the bolt head would work? How much did you have to take off of the end of the bolt? I'm trying to visualize what the install looks like with these factory side plates.
I'd rather eat worms than to have to pull the wheels for this install, but if I have to I will..
Old Jan 14, 2015 | 05:53 AM
  #44
sdetweil's Avatar
sdetweil
sure would be nice if there was a hole in the side plate! Like B&W and others have added.
Old Jan 14, 2015 | 09:48 AM
  #45
Ferguson65's Avatar
Ferguson65
I had to take off a VERY minimal amount. Minimal enough that if you aren't paying attention you may really never notice. But, as a mechanic I'm somewhat **** with my stuff and it was something I noticed. I think the extra washer would have made it a hair short. There is very little space to work with between the side rail and frame.
