Rear suspension
Old Jan 4, 2015 | 02:44 PM
Runky's Avatar
Runky
Have you checked the lug nuts? The shocks look old but don't look like they blew out. Also, is the feeling you get a high/low speeds, only going over bumps, etc.
Old Jan 4, 2015 | 02:58 PM
Collin Wersal's Avatar
Collin Wersal
I just found a hose with a white plastic tip that comes out of rear diff. It was not hooked in. Any idea where it goes
Old Jan 4, 2015 | 02:59 PM
Collin Wersal
Low speed. Like just starting out
Old Jan 4, 2015 | 03:01 PM
Shaneb75's Avatar
Shaneb75
Strokin Okie
Your probably looking at the vent hose.
Old Jan 4, 2015 | 03:02 PM
mattdoc88's Avatar
mattdoc88
That's probably just the diff's breather, with a cap on it to minimize water intrusion. It just needs to be tied up out of the way with enough slack to not get tight when the rear suspension flexes.
Old Jan 4, 2015 | 03:08 PM
Collin Wersal
Its low speeds and high speeds and doesn't go away
Old Jan 4, 2015 | 03:12 PM
Runky's Avatar
Runky
Almost wonder if it's the universal joints on the drive shaft...especially if it's at slow/start out speed.
Old Jan 4, 2015 | 03:13 PM
Collin Wersal
And it sounded like something broke loud pop
Old Jan 4, 2015 | 03:14 PM
Runky's Avatar
Runky
Have you checked the differential fluid level?
Old Jan 4, 2015 | 03:42 PM
Collin Wersal
No I haven't. I'm gonna have to take it in. I have limited resources where I'm at
Old Jan 4, 2015 | 04:08 PM
87crewdually's Avatar
87crewdually
Check the driveline, u joints , ect. Look for any slop or play with the tires chocked and the truck not running in neutral.
Old Jan 4, 2015 | 04:15 PM
Collin Wersal
My buddy is a few hours away. He's gonna try to make it up wends so we can figure it out
Old Jan 4, 2015 | 05:57 PM
  #28
Piolet's Avatar
Piolet
While you are inspecting everything also check your rear leaf packs. It won't explain the fluid but might explain the noise or chatter. And also check the shackles, I had one break a few years ago on an Explorer .
Here is a pic of mine. Notice the broken one on the right.
Old Jan 25, 2015 | 03:53 PM
  #29
Runky's Avatar
Runky
Wonder if he ever figured out what the cause was?
brentkhack
Feb 6, 2017 08:23 PM
week0019
2004 - 2008 F150
Jul 26, 2011 12:07 PM
jasonetc
Jul 18, 2007 12:09 AM
MENESLIS
13
Apr 23, 2004 07:56 AM
