Are there any major changes that have to be made in order to prep for the swap? I do know the 302 is out of a 94 gt or cobra I believe. Thanks for the help!
You have to change the frame towers that hold the engine mounts, swap to a V8 engine harness from ideally another 94 truck, install the V8 rad and hoses, and plug in a 5.0 PCM.
How easy it to change frame towers and what's the cost on a swap usually range from
From what I remember the 4.9s will unbolt, but the 302s generally have a couple of rivets on the frame towers that you can replace with Grade 8 bolts/nuts. Cost is minimal -- 10s dollars range normally.
Its the driver's side mount that requires 3 rivets removed and replaced with bolts for the 302 engine perch to mount to the crossmember.
The passenger side for both 300 and 302 perches are bolted in place.
Stock, maybe not so much to gain. Compare the specs. Note the torque and the RPM range where peak torque is made.
All stock no but it's dumb easy to get 250-275hp out of a 5.0.. you put a cam in it and install an exhaust system like everybody does anyway... that's it.
But yeah.. choose a 5.8 instead and you get the same HP and more torque than both of the smaller motors make at any rpm.
