I just installed a coolant filter and flushed my system. The video I watched beforehand states that after you flush it with water 2 or 3 times, you add 3 gallons of coolant, then top it off with water. When I did mine, after 3 gallons of coolant it would only hold like almost one gallon of water. Is this normal? I'm assuming there is still water in the engine? I've never filled coolant this way. I just want to make sure I've got the right ratio of water in there. Everything appears to be operating correctly.
Unless you pull the block drains, then draining from the radiator only will only drop 1/2 the cooling system, which is a 27.5 qt. capacity. You really needed at least 3.5 gallons of full strength coolant topped off with water to get to a 50/50 mix.
I did basically the same thing last week. Drained radiator and got about 4 gallons, pulled the drivers side block plug and got about another gallon (this may not be correct on the amount from the block), but it did give less than the radiator did. When it went back in I was only able to get about 4.5 gallons into the system. Coolant is at the new level on the degas bottle and after reading all the threads on this, I'm still wondering if I got it all or if I did the flush correctly.
So pulling the radiator plug and the block plug will remove all the coolant except whats in the heater? If that is the case, then the heater holds the other 3 gallons?
I don't know that pulling the block plugs gets ALL the coolant out, but I believe it yields more than just draining from the radiator. The intent for pulling the block plugs is that you get as much as possible out of the system when flushing and to clean out the nooks and crannies that don't make it to the radiator. I was more concerned that he didn't get the correct concentration of coolant back into the system.
FWIW: I did some course work on changing coolant types at job this week and my manufacturer recommends at LEAST three system flushes before changing coolant types, especially on incompatible coolants. I think you should be fine.
and that brings us back to the OP's question and why I'm wondering if I messed up..
If you pull the drivers block plug and the radiator plug, is most of the coolant gone? The coolant on my rig was replaced by the previous owner (he claims) just before I bought the truck, with Ford gold. After reading all the good things about it, I replaced my thermostat (was 182-186 on average) and put in the red ELC last week. If I were to have put straight ELC, my 50/50 mix would have been about 75/25% and not 50/50 as everybody says it should be.
I poured in a gallon of red, gallon of distilled, gallon of red, gallon of distilled and it was to the mark on the degas. Started truck, ran around until warm, added another 1/2 gallon of 50/50 mix and done. Like the OP, only got about 1/2 of what should have been nearly 8 gallons.
I sat 4 gallons of red and 4 gallons of distilled on the bench, I have 1 gallon of red and 1.5 gallons of 50/50 mix left and scratching my head, same as Jeremiah77.
Drained radiator (degas bottle was at the minimum mark - got out 14.75 quarts (3.7 gallons)
Drained passenger side block - got 3.25 more quarts
Drained drivers side block - got 2.5 more quarts.
Total drained fluid - 20.5 quarts or 5 1/8 gallons (apprx). The total system holds 27.5-28 quarts. So 7-7.5 quarts were left in the system.
Note - I did not remove the lower hose.
Agree. Whats left is the heater core and hose.
So switching fluid type from Gold to red ELC.... does it hurt anything to mix them? Using your numbers, I got 13.75 from the radiator (about 4 gallons) 3.25 from the drivers side (about a gallon), that's close to 5 gallons and when refilling I put back exactly 4.5 gallons at 50/50 strength red ELC and I'm at the degas min mark.
Do I need to go back and do this again several times to remove the 7-7.75 quarts from the heater and the 2.5 quarts from the pass side, which contained Ford gold? I've ran the truck for about 50 miles this way if that matters?
The OP added 3 gallons (12 quarts) and less than a gallon of water, that put him at about 80/20 mix, not even close to the recommended 50/50.
The OP flushed his radiator until all that remained in the engine was water (essentially). If you add 3 gallons of concentrate and top off with more water, then you only get "3 divided by 7" or 42.86%
also 13.75 and 3.25 quarts is ONLY 4.25 gallons (15% or so LESS than 5 gallons).
I would not want to mix Gold and ELC coolants. IMO you need at least a water flush.
Knowing that, the OP should be close to the 50/50 mix.
I see that I need a water flush. I finished just before I left to go this business trip, sitting in Japan as I type and won't be back to the truck until 15 JAN. Will it hurt to let it sit as the truck is parked until I get home?
Personally I do not think it would hurt anything in that short of a time period.
Two reasons not to mix (and it would seem that you are leaving about a gallon of Gold in the system) would be that:
1. People believe that Gold mixing with other coolant types increases the chance of solids or gelling.
2. The corrosion and cavitation protection is MUCH less effective if two different chemistry coolants are mixed.
Thanks for all the replies! Just to add to the discussion...I went with the Motorcraft Gold coolant. The previous owner had replaced the radiator and had the system filled with the cheap green stuff. I left the t-stat in, flushed with hose water twice, then flushed with distilled, then added coolant and topped off with more distilled.
Jeremiah. I would recommend you drive a while and do a few more distilled water rinses, then drain without thermostat, drain block plugs and replace with fresh gold. With that few rinses, you are leaving a few percentage points of the old green coolant in the there and that is not good for your oil or EGR cooler. I would also test with a hydrometer to make sure you are truly at 50/50 antifreeze and water. You need maximum boil over protection and freeze protection. It sounds like you may be about half a gallon short of Ford Gold coolant, meaning you are just over 40% coolant! which is not ideal. Just my opinion from reading this post, but I think better on the safe side......
