Gasket question
Old Jan 1, 2015 | 11:48 PM
EightGodzillas's Avatar
EightGodzillas
Gasket question
I bought an Edelbrock Performer 400 for the 351m. The guy who owned it before me had a lot of red formagasket between the intake and the pan that goes beneath it (I don't remember the name of it, it is thin aluminum). I have never liked the idea of using that stuff. However, I can't find what gaskets I will need. Any help would be appreciated.
In short: what gaskets are needed to replace the intake manifold with an Edelbrock Performer 400?
Old Jan 2, 2015 | 08:33 AM
Gary Lewis's Avatar
Gary Lewis
All you need are the intake manifold gaskets. This view from Amazon shows the full set for $28 and the set without the turkey pan for $14. In any event, do not buy the Mr. Gasket ones as their products are typically of really poor quality.
Also, I wouldn't use the neoprene end gaskets. That's where I do use RTV. Build up a 1/4" tall bead across the dam on either end, making sure there are no gaps, and lay the turkey pan in. Then build up a bead on top of the pan above the dam and, with the gaskets in, lay the manifold in. Install at least the corner bolts and snug them down enough to get the RTV to squeeze out all of the way across, but do not tighten them until the next day to allow the RTV to set up. The next day tighten all the bolts down in the proper order, but do it in at least two steps with the first step being half torque.
Now, here's where I show my lack of memory. If the mounting bolts point straight up, and some engine's bolts don't, I install some studs in the corner holes before you start to install the manifold or turkey pan. That ensures the things align properly. And if you don't have studs just make some by cutting the heads off of some longer bolts.
Old Jan 2, 2015 | 09:08 AM
ctubutis's Avatar
ctubutis
IIRC the turkey pan *is* the OEM intake gasket - that plus the two end things (on the front and rear) which are generally not used and beads of RTV (I use the black fuel-resistant stuff) used instead.
Alternatively, one can forego the turkey pan and use unique gaskets, one per side (along with the two end things which, again, are not used) as is depicted on that Amazon page.
For my Performer 400 installation, I used the latter - unique strips and no turkey pan. But I also used a bit of, um, what's that stuff called... it's a Permatex product... High Tack, that's it! I used a bit of that on the sides, and black RTV to form the front/rear gaskets.
I forget the exact reasons why - and I haven't taken my installation apart to see how it's doing - but I now sometimes wish I had done the turkey pan... I think it was something about oil cooking onto the bottom of the intake but don't remember for certain....
Old Jan 2, 2015 | 09:52 AM
Gary Lewis's Avatar
Gary Lewis
Chris is right - the turkey pan is the gasket when it is used. Sorry. But the Amazon page shows it correctly.
And, the reason for the turkey pan is to keep oil from hitting the exhaust crossover and burning. Also, to keep hot oil from heating the bottom of the intake and, therefore, the incoming air/fuel charge.
PapaBearYuma
Apr 14, 2017 04:33 PM
my-ford
Jan 18, 2015 06:32 PM
black water
Nov 1, 2010 10:17 AM
fozzy
Aug 1, 2008 08:03 PM
frankster123
Mar 31, 2003 06:00 PM
