beep beep, from front speakers
Old Jul 20, 2003 | 02:39 PM
55-willys's Avatar
55-willys
i just got done installing a new in-dash stereo. everything went great thanks to help from this forumn. the only thing now, is when i turn my stereo off it makes a beep, beep, pause, then beep, beep, sound from the door speakers. its real faint, but i can hear it. the other thing is when i turn the geadlights on the stereo goes off for second then comes back on, salso when i turn the lights off it does the same thing. i tested the wires that i hooked up to, to make sure which one was full time 12 volts and which one was the 12 volt key on. everything works. also, there were a wire or two that i didnt use. could i have hooked to the wrong 12 volt, key on, wire. i remember seeing a post, or site, that showed which wires to use from your old wire harness but cant find it. i went to the install doctor site but cant access the wiring portion, im on the web.
Old Jul 20, 2003 | 03:37 PM
Tacocaster's Avatar
Tacocaster
Make sure all your wires from the radio to your wiring harness are hooked up correctly.
Old Jul 20, 2003 | 03:50 PM
Bikeitswift's Avatar
Bikeitswift
Go back and double check that each wire, one at a time is hooked up properly. For nowrun the full 12v wire (16 gauge minimum) right to the battery postive post, and the ground to a screw into metal on the body (it wouldn't hurt to run it to the battery ground for now). Now try it. If your problem is solved, make the positive connection into a permanent one, and get a good ground. So many problems are caused by inadequate grounds. It doesn't hurt to add grounding straps from your engine block to the body, and another from the battery negative to that body ground.
Old Jul 21, 2003 | 07:16 AM
gudoldboy's Avatar
gudoldboy
I dont know what kind of Head Unit you have but on most Pioneer and Sony Head Units if you dont take the faceplate off they will beep at you to remind you and it is through the front speakers.
Did you hook up the dimmer feed on the stereo to your dash wiring? That could be the cause of the flicker when you turn the lights on and off.
Aaron
Old Jul 21, 2003 | 09:36 AM
cowtown's Avatar
cowtown
Yeah I seem to remember the beeping being part of the "hey don't let me get stolen" warning.
Old Jul 21, 2003 | 09:50 AM
luke_trash's Avatar
luke_trash
it wasn't faint though
My pioneer has no beeping alert.
My sony units did though.
I use to get a faint "click click" noise from a kenwood unit I had.
it was from having the switched 12v wire hooked up full time.
the radio just kinda always made that noise, when turned off for some reason.
Old Jul 21, 2003 | 12:01 PM
55-willys's Avatar
55-willys
never thought of that, beeping so i wouldnt forget to remove the faceplate. the radio is about 8 years old and the instructions are long gone. ill try removing the faceplate and see if that does it, im sure thats the cause of the beep beep. as for the wiring, i simply found a constant 12 volt and hooked that to the constant on the sony and then turned the key to acc. and hooked that 12 volt to the 12 volt on of the stereo. i dont think the sony has a wire for when you just turn the light on to light up a display of any kind. its either on or off. but i think, now, that the original radio would light up with the running lights.
MrManimal
Electrical Systems/Wiring
13
Sep 11, 2014 02:12 PM
chappys4life
Jun 29, 2012 12:05 AM
chadwick623
Jul 22, 2011 02:28 PM
Fordenthusiasts
Apr 23, 2011 10:19 AM
mel63
Aug 22, 2006 11:13 PM
