96 Ford Explorer making morse code through radio
Old Jul 22, 2011 | 12:11 PM
chadwick623's Avatar
chadwick623
Exclamation 96 Ford Explorer making morse code through radio
1996 Ford Explorer, while driving all the lights came on, on the dash, and there was a morse code beeping through the radio speakers(Im not sure if its comes from the speakers - sounds like its in the dash), 3 long beeps then 2 fast beeps, followed by 2 long beeps, and then repeats after a few sec pause, I pulled over and now it wont start or anything, and it will continually keep doing the beeping.
Everything is factory, and a regular key
Please let me know if ya have heard of this or know what it is, and how to fix it. Thanks
Old Jul 22, 2011 | 01:33 PM
aquanaut20's Avatar
aquanaut20
Do you have a theft deterrent system?? Maybe BIG BRO has shut you down!!!.. Philip
Old Jul 22, 2011 | 01:37 PM
chadwick623
There is a factory key fob but that set an alarm and lock and unlocks the doors, I know for sure its not the factory radio or seat belt. The vehicle is payed and has no aftermarket device on it what so ever.
Old Jul 22, 2011 | 01:40 PM
aquanaut20's Avatar
aquanaut20
Sorry this is a new one on me, only time I have come across anything similar was on BAIT cars..... radio triggered kill on pursuit..... Philip
Old Jul 22, 2011 | 02:18 PM
chadwick623
Ya, no bait car here, Ive owned if for 5 years, I got it started, and everything was working fine till I put it in drive and pressed the break pedal, and then it lost all electrical power went out (windows, a/c but not the radio but there was more static but could still here the radio). While that was all going on the ABS light was on, then I shut it off and then it wouldn't start again, like it was dead.
I have 3 error codes
P0761 Shift Solenoid C Performance or Stuck Off
P0340 Camshaft Position Sensor Circuit Malfunction
P0300 Random / Multiple Cylinders Misfire Detected
Do ya think any off these codes could cause this problem?
or any suggestions?
Old Jul 22, 2011 | 02:28 PM
aquanaut20's Avatar
aquanaut20
With a power fluctuation as you describe, these could be random ghost codes. I would clear them and see if they return...
Having said that, I would clean all the electrical connections to/from the battery and as many grounds as you can find. Check the battery voltage, start the vehicle and measure charge rate.... Philip
JessieDM
19
Dec 30, 2024 04:44 PM
HelpinMomma
Feb 21, 2022 12:06 PM
87&97Aerostrar
Aerostar
21
Feb 17, 2017 09:06 AM
shadyEats
1983 - 2012 Ranger & B-Series
13
Jun 15, 2015 02:00 PM
EconolineFan
21
Nov 27, 2013 05:39 PM
