Noise when taking off?
Old Jan 1, 2015 | 08:52 PM
copen93's Avatar
copen93
I hear a trampoline spring type noise when I apply light pressure when taking off slowly. It sounds really weird, I have no idea what it is. Like if you were bouncing on a trampoline and the noises the springs make that's what it sounds like. 93 f150 4.9 4x2
Old Jan 1, 2015 | 10:31 PM
Toplait's Avatar
Toplait
Where is the sound coming from?
Old Jan 2, 2015 | 01:56 PM
copen93's Avatar
copen93
Sounds like it's under the dash or something near my feet.
Old Jan 2, 2015 | 02:15 PM
madpogue's Avatar
madpogue
Automatic or manual transmission?
Old Jan 2, 2015 | 07:00 PM
copen93's Avatar
copen93
E40D automatic transmission.
Old Jan 3, 2015 | 05:33 PM
jaagen's Avatar
jaagen
I would look at drivetrain parts (I.e. wheel bearing, u-joints, breaks, ball joints). Do these truck use a speedo cable? Could make noise inside the protective sleeve
Old Jan 3, 2015 | 07:54 PM
Plowboy34's Avatar
Plowboy34
U-joints can start making a noise like that when they start going bad. It will progressively get worse if that's what it is. See if they have any play in them and if they have a zerk fitting shoot some grease in them and see if it helps.
Old Jan 3, 2015 | 08:06 PM
Mattjmulligan's Avatar
Mattjmulligan
I've got a bad motor mount and an iffy trans. mount on my truck (1990 f150 4.9 5 speed) and it makes a noise similar to what you're describing. You might want to check that as well
Old Jan 4, 2015 | 01:17 PM
Island Time's Avatar
Island Time
Nope. Changed over to electronic speedo in '92.
Old Jan 4, 2015 | 02:16 PM
eakermeld's Avatar
eakermeld
Check for any loose shields on the exhaust system. They will vibrate at different frequencies as engine RPM changes and can make some STRANGE noises.
Old Jan 4, 2015 | 02:36 PM
Mattjmulligan
Yes that too I forgot about hat because all of mine have fallen off or been taken off by now
mybigredford
Nov 9, 2004 09:47 PM
Lucca
Oct 4, 2003 08:34 PM
