HPOP Question
Old Jan 1, 2015 | 12:14 PM
BLADE35's Avatar
BLADE35
Yes you could have updated hpop
Post all of the sensor values hot @ KOEO--idle--2500rpm
Icp
Icpv
Ipr%
So we need 3 values per each sensor listed
Make sense?????
Old Jan 1, 2015 | 12:15 PM
BLADE35's Avatar
BLADE35
Your icp sensor is bad
If the value was .30 Volts @ KOEO
Old Jan 1, 2015 | 12:22 PM
DieselVol's Avatar
DieselVol
It is. That's the one that is super hard to get to on a 2003, later moved to another spot, and needs to have the pigtail changed at the same time?
Old Jan 1, 2015 | 12:31 PM
BLADE35's Avatar
BLADE35
Yes so far icp looks bad
Triple check those numbers though per my post #16
Yes you are correct the early trucks icp is in a bad spot under turbo the sensor always gets coked
When you can't start it ckeck those values again just to make sure and then unplug ICP then try to start
Old Jan 1, 2015 | 12:34 PM
DieselVol's Avatar
DieselVol
Will do. Thanks to all all for the help.
Old Jan 1, 2015 | 12:40 PM
78fordman's Avatar
78fordman
He is tuned, take it back to stock then get sensor values.
Old Jan 1, 2015 | 12:42 PM
BLADE35's Avatar
BLADE35
Oh crap
Good catch fordman
Redo test tunned stock
Old Jan 1, 2015 | 06:30 PM
DieselVol's Avatar
DieselVol
The results are in:
All numbers sitting in my driveway, ECT at 200 degrees:
At idle:
ICP: 649
IPR: 19.7
ICV: 0.85
At 2500 rpm:
ICP: 1494
IPR: 38
ICV: 1.71
At KOEO:
ICP: 151
IPR: 14.4
ICV: 0.38
That's what I got, now what does it all mean?
Old Jan 1, 2015 | 09:02 PM
mustang_309's Avatar
mustang_309
Originally Posted by DieselVol
All numbers sitting in my driveway, ECT at 200 degrees:<br />
<br />
At idle:<br />
<br />
ICP: 649<br />
<br />
IPR: 19.7<br />
<br />
ICV: 0.85<br />
<br />
At 2500 rpm:<br />
<br />
ICP: 1494<br />
<br />
IPR: 38<br />
<br />
ICV: 1.71<br />
<br />
At KOEO:<br />
<br />
ICP: 151<br />
<br />
IPR: 14.4<br />
<br />
ICV: 0.38<br />
<br />
<br />
Your ICP sensor is bad and possibly the ICP electrical connector. The ICPV's should be .18 to .24 at KOEO
Old Jan 1, 2015 | 09:07 PM
DieselVol's Avatar
DieselVol
Originally Posted by mustang_309
<br />
Cool and thanks. Is that a do it yourself job or one for the pros? I do work on my Harley, but they have a good step by step service manual with pictures and there's often a YouTube video to boot.
Old Jan 1, 2015 | 10:45 PM
BLADE35's Avatar
BLADE35
You will be fine
There's a post in the tech folder by william4x4
Pretty we'll what I followed I do mine from top
Old Jan 1, 2015 | 10:47 PM
DieselVol's Avatar
DieselVol
You will be fine
Will check it out. Thanks.
Old Jan 1, 2015 | 11:02 PM
  #28
DieselVol's Avatar
DieselVol
You will be fine
Well I've seen it from the top and the bottom...and I'm going pro on it. Main reason: if I don't finish a Harley project tonight, no big deal. If I don't finish a truck project, I'm walking to work tomorrow.
Jack3d_Dually
Oct 27, 2018 09:07 AM
graintrain
Mar 1, 2017 08:46 PM
20036.0Harrison
Nov 29, 2016 10:25 AM
VictorwithaC
Aug 5, 2016 06:55 PM
1965Falcon
Sep 18, 2014 05:43 PM
