2015 BS thread. Bring it!
Old Jan 27, 2015 | 11:00 AM
  #2266
fabmandelux's Avatar
fabmandelux
Out the door. Have a great day guys!
Old Jan 27, 2015 | 11:01 AM
  #2267
56panelford's Avatar
56panelford
Originally Posted by 67nukeford
Nice to hear you didn't take part in any of that nasty weather, John!
We got 2 1/2" 2 nights ago.
Old Jan 27, 2015 | 11:06 AM
  #2268
67nukeford's Avatar
67nukeford
Veteran: Navy
We've had a total of 4 inches so far this year. Way under our normal. Won't hear me bitch about it, though!
  #2269
67nukeford's Avatar
67nukeford
Veteran: Navy
Have a good day, bud!
Old Jan 27, 2015 | 11:08 AM
  #2270
Seabiscuit-P3's Avatar
Seabiscuit-P3
Veteran: Navy
Veteran: National Guard
Belated good morning Oregon and everyone everywhere else. 41.1, wet, dank and fog. Had nearly 0' visibility. Seems to have lifted to about 50-75' depending where you are at.
Originally Posted by TinyWonder
I hear you about debating weather or no to try it yourself. I'm cheap and would probably give it a try... especially for almost 1K.
I agree... second opinions are usually a good thing.
I was going to say when one battery goes bad that unfortunately it's better to replace both at the same time. But since it was a warranty replacement that's a different story.
Can't seem to get them to both fail at the same time. The drivers side looks like it just came off the shelf and tested as if it were a brand new battery so with the Pax side warranty it seems a waste to throw a $100 bill at a battery that looks and tests as if it were new.
Replaced both batteries together in 2011. Then, the Passenger side in 2013 (warranty), the drivers side 03-2014 (warranty) now back to the passenger side.
I'm going to crawl under the hood today and see what I can see back there in the well. I'm seeing where there have been a lot of problems with the R & R of these things. Found this https://www.ford-trucks.com/forums/1...l-trouble.html
Also found several You Tube Videos, some are O.K., some not so good as far as running into problems. Also found several references to taking it out without removing the turbo, but in each case it seems that they heated a wrench up and bent it to fit. The little sucker doesn't look like it should be too much trouble, but I'm seeing an awful lot with the tappet broken off. Just afraid I'll get in there and fine the same thing and not have the proper tools to extract it. Also having a hard time swallowing the inflated $100 added on to the pump price at the stealership plus the $100 an hour labor rate.
Old Jan 27, 2015 | 12:12 PM
  #2271
SpringerPop's Avatar
SpringerPop
Originally Posted by Seabiscuit-P3
Jon told me that they had the diesel mechanic come over and check it. He said the tandem fuel pump was definitely leaking and that it wouldn't be long before I would have to address the problem. Said the Turbo has to be taken out to get to it. He said it is about a 5 hour job and $766.26 to R & R it. Said the pump was about $200 of that which seems to be a tad bit high to me.
I think I'm going to go down the road and talk to Corey and see if he would change it for me for a lot less.
Edit: If I got the right part, F6TZ-9350-A. Riffraff has a Ford OEM for 99.61, Ford Parts (Fordparts.com)@ 173.59. RockAuto run from 70 to $98 but are all post market - no Ford (Motorcraft)
Just not sure I want to try and tackle that myself. I've found some horror stories about things breaking and / or dropping down into the cam.........
One thing you might consider, since you're going to be in there anyway, is to convert it over to the late-model 7.3 system, where a frame-rail Bosch-type electric pump is used. The fuel pump hole in the valley gets sealed off with a freeze plug.
Pop
Old Jan 27, 2015 | 06:15 PM
  #2272
kjvforme's Avatar
kjvforme
afternoon guys been out working on my Bug Engine, just about ready to close up the case.
Old Jan 27, 2015 | 06:16 PM
  #2273
fabmandelux
Afternoon Rob. I'm in early to do a bunch of paperwork.......sigh...
Old Jan 27, 2015 | 06:24 PM
  #2274
kjvforme's Avatar
kjvforme
Afternoon Don how goes? Hey when were you coming down?
Old Jan 27, 2015 | 06:27 PM
  #2275
fabmandelux
I hate paper work........... We should be down around mid Feb. Can you get me Maudine's address? I'd like to plug it into Google Earth...
Old Jan 27, 2015 | 06:41 PM
  #2276
Seabiscuit-P3
Veteran: Navy
Good afternoon all. In early to work on Taxes, mortgage stuff and I might even try a little crying in my beer.
Went out and was looking over the pickup. The leak really isn't all that bad but it is wet there and is in need of getting fixed in the not too distant future.
Old Jan 27, 2015 | 08:41 PM
  #2277
Old93junk's Avatar
Old93junk
I need to get off here so I can go out and pull the Holley off the Ranger for re-build.
Old Jan 27, 2015 | 08:51 PM
  #2278
Seabiscuit-P3
Veteran: Navy
I'm done for the day. Gonna play on the lap top while the wife and I watch an educational movie on the big screen!
Old Jan 27, 2015 | 08:57 PM
  #2279
kjvforme's Avatar
kjvforme
What the educational movie?
Old Jan 27, 2015 | 09:04 PM
  #2280
Seabiscuit-P3
Veteran: Navy
Guardians of the Galaxy on DVD. Came in the mail today from the Disney Club that the wife belongs to.
We feel a duty and obligation to preview it to make sure that it is O.K. for the grandkids to watch on their next visit.
