Difficulty getting M5OD into 1st gear
Old Dec 30, 2014 | 10:09 PM
roseofmike's Avatar
roseofmike
96 f-150 4x2 130,000 miles.
Really have to work the shifter to get into 1st gear from a dead stop. Once rolling, all gears shift smooth as silk. I use to be able to shift into reverse and then move into 1st smoothly...but not anymore.
Getting so bad that I have to shift into 1st gear as I decelerate. 1st gear engages around 7-10 miles an hour easily, but then I have to keep the clutch in while waiting at lights.
Clutch? Synchronizer? Fluids are in good shape.
Thanks in advance!
Old Dec 30, 2014 | 10:33 PM
PlumCrazy7's Avatar
PlumCrazy7
Probably synchro, is it hard even shifting from 2 to 1? Is it easier if you rev-match? If rev-matching helps it is a good indication of wore synchros
Old Dec 30, 2014 | 11:21 PM
Ed Bamba's Avatar
Ed Bamba
My truck did the same thing until I replaced the clutch, pressure plate, flywheel, TO bearing and hydraulic system. I just dealt with until the slave cylinder finally went out (200K + miles). No clue which part actually fixed the hard shifting problem, but since I was replacing the slave, I went ahead replaced everything mentioned. Didn't touch anything inside the transmission.
Old Dec 30, 2014 | 11:37 PM
88n94's Avatar
88n94
Have you checked the fluid level in the clutch master cylinder? Don't forget to remove the rubber cup under the cap. Your clutch may just be not disengaging enough. If this was the case, you would also probably have trouble shifting into reverse.
Old Dec 31, 2014 | 09:00 AM
roseofmike's Avatar
roseofmike
Thanks for all the reply's.
Plumcrazy...if you mean shifting from 2nd to 1st while in motion, no...provided I'm at the right speed as I down shift. At a dead stop however, with engine running and clutch depressed, reverse match from 2nd to first is difficult. I usually find it easier to match using the reverse gear..but that too has become difficult lately.
Ed....good insight
88n94...Fluid level looks good in the master. However, I find it a little tricky to determine just how much to add as the rubber cap kind of covers things up. When I topped it off last, I had a small amount of spill over when I reset the rubber cap and lid.
I would say that I'm an above average user of downshifting when coming to a stop. I'm sure that has taken a toll on some levels.
Old Dec 31, 2014 | 09:42 AM
'89F2urd's Avatar
'89F2urd
Are you sure your clutch is disengaging completely? Does it shock the drivetrain when you put it into 1st? Does it engage with foot close to floor on takeoff?
You can put truck on incline, with it off and in 1st gear, and see if it'll move with clutch pedal to floor.
Old Dec 31, 2014 | 01:40 PM
roseofmike's Avatar
roseofmike
89F2urd....there is a very,very, very slight lurch shortly after I get the car in 1st gear...but it does not cause the car to roll forward on level ground. In the same scenario, the truck will roll backwards on an incline. I feel like after 130K I should replace the clutch anyway. Who knows.
Old Dec 31, 2014 | 01:42 PM
'89F2urd's Avatar
'89F2urd
and how close to the floor does it begin to engage the clutch? at 130k its hard to believe the synchros are bad, but certainly possible...a lot of variables there to cause failure.
Old Dec 31, 2014 | 04:04 PM
phoskins's Avatar
phoskins
I have a '96 w/ 167k that can be difficult to put in first gear. It got better when I changed the fluid, but it's still not great. Change your fluid first if you haven't.
I only downshift when slowing to a stop when I need engine braking. I can't remember using first gear for engine braking though, seems tricky to do so comfortably. I put it in neutral when slowing under normal conditions and when stopped in traffic.
Sometimes it seems like I can't find first when stopped. When that happens, I keep the clutch pedal depressed & slide the shifter backward into fourth, then, for some reason, I can get back into first easily. I checked my shift forks, thinking they could be worn, but they were still in good condition.
Check/change fluids, then evaluate clutch condition. If you're not getting unavoidable grinding, you're not ready for a rebuild i.m.o.
Old Dec 31, 2014 | 09:33 PM
IDIDieselJohn's Avatar
IDIDieselJohn
Sounds like either your clutch master is done or your slave.
Mine was doing the same when my slave was going out.
Old Jan 1, 2015 | 09:48 AM
warren561's Avatar
warren561
That's my experience as well. Occasionally, I could not get my truck into 1st even when stopped. I'd have to pump the clutch a few times or slip it into another gear then go into 1st.
I also had a problem where it wouldn't want to go into 2nd when already rolling.
Changing the clutch, pressure plate, throwout bearing and slave clyinder helped with the getting into 1st gear issue.
However, I still can't get it into 2nd every once in awhile... I think that's related to a worn synchro. I'll wait until the transmission dies and address that with a rebuild M5OD or a ZF5 conversion.
Good luck.
Old Jan 2, 2015 | 12:46 PM
roseofmike's Avatar
roseofmike
'89F2urd....seems like all the action happens just off the floor. the truck begins to roll literally the moment I begin to release the clutch.
Old Jan 2, 2015 | 01:10 PM
'89F2urd's Avatar
'89F2urd
typical indications of a faulty master/slave. unfortunately you have to pull the trans toget to them, you should use OEM replacements, the xyz auto part stores have low quality stuff, and since its so hard to get to you want it to last.
misewell do the clutch while in there too. also, your worn setup has put excessive strain on your 1st and reverse synchros...but fresh parts should clear it up quite a bit. a bottle of lucas helps worn synchros also.
Tonto Kowalski
Nov 29, 2014 12:53 PM
jerrylynnb
1983 - 2012 Ranger & B-Series
25
Mar 10, 2012 03:50 AM
rlpatte
Jan 28, 2012 06:41 AM
Motorhead351
Jul 17, 2008 06:24 AM
zach_barrow
Feb 4, 2008 09:10 PM
