Ford Explorer engine ticking
Old Dec 29, 2014 | 09:23 PM
thefox48's Avatar
thefox48
Hi all
Just a quick question, my 2006 4.6 explorer has a ticking noise when you first start it up. It lasts for about 10 seconds and goes away. Sounds like a valve tappet when the oil needs changed etc. It has been running 5-w-20 in it like the book says. I'm going to change it again and see if it helps.
Has anyone else run into this. Any luck changing to a different grade.10w-30?
Thanks
Larry
Old Dec 30, 2014 | 01:43 PM
LX Sport's Avatar
LX Sport
What oil filter are you using? Some oil filters will let the oil drain back into the oil pan, then when you start the engine it takes a few seconds to pump the oil back up into the engine. The Motorcraft FL820S is a good filter for that engine.
George
Old Dec 30, 2014 | 04:05 PM
thefox48's Avatar
thefox48
Thanks
Ill give this a try when I change the oil next week.
Larry
hhansen59
Sep 27, 2012 11:30 PM
BLK94F150
Oil & Lubrication
Jun 22, 2012 02:11 AM
Josue
Jan 23, 2011 08:48 PM
04mudslinger
2004 - 2008 F150
19
Apr 30, 2008 10:58 AM
micgang
Aug 13, 2003 04:54 PM
