Modular V10 (6.8l)
I've ordered the improved y-pipe
Old Dec 29, 2014 | 08:59 AM
hodge5's Avatar
hodge5
For the average joe, how hard is it to install? I am waiting for the pipe to come in the mail, and I'm thinking through things. I am a competent welder, but I haven't worked much on exhaust, especially in place. Can I assume that the y-pipe needs to be welded in place, so that everything correlates? Tack it together, then remove it and weld it together? How have you guys, who've done it yourself, tackled it? Or, is it more prudent to take it to a shop and have them do it? I am competent to measure twice and cut once, although I see in my mind that this could go south with inexperience.
Old Jan 1, 2015 | 11:46 AM
acf6's Avatar
acf6
We left everything in place, cut out the old y pipe, then lined up the new one on top of the old pipe and cut it more precisely, tacked it in place, then removed everything to fully weld it. Wasn't too bad, took us maybe 2 hours which included eating pizza
Old Jan 1, 2015 | 12:20 PM
hodge5's Avatar
hodge5
Thanks, acf. I'm looking forward to getting it installed.
Old Jan 12, 2015 | 09:25 AM
Diamnd1's Avatar
Diamnd1
I took mine to a local muffler shop. Had it in in 20 minutes for $40. Best mod outside the 5 star tuner.
Old Jan 12, 2015 | 01:25 PM
TSM35's Avatar
TSM35
Which pipe
Just curious whose pipe you ordered. Last time I checked there were several on the market.
Old Jan 12, 2015 | 01:58 PM
hodge5's Avatar
hodge5
This one-
http://www.ebay.com/itm/301422040311?_trksid=p2060778.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
The others that I looked at- they didn't look as well designed or simplified, they didn't seem to reduce back pressure as much, and this one is what I read about on the forum, and saw photos of installed.
I leave for Haiti on Friday morning, so this project will have to wait until I get back. I can't wait to get it installed, though. I need to round up a gasket and some donuts.
Old Jan 29, 2015 | 04:57 PM
hodge5's Avatar
hodge5
An update. I had a local shop install the y-pipe today. I don't have a lift, nor do I have the patience to wait until spring for dry ground/warm air to install it myself.
I can slightly notice a difference in sound, performance was not noticably improved- seat-of-the-pants feel is the same before and after- BUT, the slight flutter at 2000 RPM's is completely gone. I ran it through its paces, and never heard a flutter. I am anxious to see if fuel mileage increases any.
Old Feb 6, 2015 | 07:52 PM
hodge5's Avatar
hodge5
A short update- I've put about 300 miles on the truck, and I'm getting a better feel. I haven't driven it enough to check mileage, plus most of my driving is local. My guts impression is that the improvement is marginal, if there is one. Performance-wise, there is no difference. I haven't towed with it, but I do live in the mountains, and have done some hard pulls to see how it did- no difference. The only difference is sound- the exhaust under the cab floor, where the two down pipes come together, is a little more noticable than it was before. The flutter is there, but no more than before. All in all, knowing what I know now and assuming that things will stay the same, it wasn't worth the money spent. I haven't suffered anything, but I haven't gained anything, as far as I can tell. Maybe time will prove me wrong, or warmer weather will make some difference.
Old Feb 7, 2015 | 12:23 PM
DaddyDonnie's Avatar
DaddyDonnie
Thanks for the post, Hodge5.
I purchased my 2003 F-250 a few months ago with about 145K.
While going the coast of SC, I stopped by 5-Star in Florence, SC and bought the well-touted tuner. It does a great job.
I have been thinking about the upgraded Y-pipe. Your results make me lean towards not.
The past couple of days I've been checking-out plugs and such.
Yesterday I found #10 cylinder had a Dorman plug kit installed due to a blow-out. The adapter was a bit damaged, so I replaced the entire kit as I'm going to replace the remainder of the plugs and boots soon.
Thanks again for the review of the pipe, and for the Scripture verse at your sig.
Don
Old Feb 7, 2015 | 04:45 PM
hodge5's Avatar
hodge5
Don
Glad to be of help!
What improvements has the tuner offered? I have thought about one, but for what I do, I am happy with the power and performance as it sits.
Old Feb 7, 2015 | 06:02 PM
DaddyDonnie
When we were passing through Florence, we were heading to a campground on the coast. We were pulling a travel trailer which weighs about 7K.
After the tuner was installed, I noticed a better shift point (at a higher RPM)
than the factory tune.
I haven't tried the Economy Mode yet, but it could improve mpg a tad, I suppose.
I am running the Performance Tune right now. It does a good job. I don't know if it's much better than the factory tune (w/o a load) or not.
I just saw your comment about Haiti. Where were you working? I was there with some fellows a couple of years ago in Jacmel.
Old Feb 7, 2015 | 06:10 PM
hodge5's Avatar
hodge5
We go the other way- North to St. Marc, then East to Deschapelle in the Artibonite valley. We do medical clinics there, build churches, fellowship, drill wells, whatever we can get in to.
ghunt
Exhaust Systems
Nov 5, 2015 07:08 AM
Diesel cat
15
Sep 16, 2014 09:50 PM
Vinford
Nov 27, 2009 12:07 AM
Wakeboarder141
Exhaust Systems
Oct 12, 2004 09:37 PM
Pauls88gt
Sep 5, 2003 02:39 PM
